Thread Number: 164
"Outside loops in a Decathlon"
Posted by gmonkey7 on 01-27-05 at 00:10z
Can anyone provide some guidance for performing outside loops in a decathlon?
I have been flying positive manuevers and inverted flight for quite some time. I have spent a lot of time with an instructor. Now I want to try an outside loop.
I have the entry speeds from the POH. I was looking for a little detail on technique. Also, how many negative G's should you be putting on a 1978 decathlon with wooden wings?
Can a rolling 360 be flown in a decathlon?
I am flying the 150hp fixed pitch model.
Thanks,
Jim
"RE: Outside loops in a Decathlon"
Posted by Patty_Wagstaff on 05-09-05 at 00:15z
Jim
Sorry for not replying sooner. I've been away working, and just getting caught up.
Re: Outside maneuvers in a Decathalon, yes, you can do just about anything you can do inside - outside. I learned my first outside maneuvers in a 150 HP Decathalon, then switched to a Super Decathalon.
First, make sure your seat belts are as tight as you can get them. I am presuming you have double seat belts, with two separate attach points for safety.
Second, get lots of altitude.
Third, I am presuming you can fly a straight and level line upside down, and do inverted turns of at least 90 degrees right and left, and preferably, can do a level inverted 180 and 360 turn. If not, practice that first until you're good at it.
Fourth, assuming the above conditions are there, start with a 1/2 ouside loop from the bottom up. So - roll inverted, have about 160 mph and then push around until you see the horizon. You'll need a little left rudder instead of right in the push, and knowing Decathalon's, most of the time you'll probably be pushing trim to lighten the stick force.
Practice the half loop and let me know how it goes. Then we'll go from there.
Sure thing. I learned how to do rollers in a Decathalon.
Posted by Patty_Wagstaff on 05-09-05 at 00:23z
Jim
With regard to your question about how many negative G's to put on the airplane, respect the design limitations and look at the placards.
Posted by ghmorris312 on 09-04-05 at 03:53z
Jim,
I would recommend getting instruction in the maneuver first; there are many good instructors and schools that can teach outside maneuvers in a Decathlon.
-Greg Morris-
