Thread Number: 85
"Right Click disabled?"
Posted by vgbaron on 11-02-01 at 03:44z
Don't know if it's intentional but the right click context menu is disabled in the forums. When I'm reading messages, I like to right click back to the message list. It's easier than moving the mouse and clicking the arrow ( IE5 ).Just my two cents worth:-)
Vic Baron
- RE: Right Click disabled?,Ben Chiu, 03:48z, 11-02-01
- RE: Right Click disabled?,vgbaron, 01:41z, 11-03-01
- RE: Right Click disabled?,Ben Chiu, 02:42z, 11-03-01
- RE: Right Click disabled?,Madape, 23:47z, 11-04-01
- RE: Right Click disabled?,Ben Chiu, 08:25z, 11-10-01
- RE: Right Click disabled?,jerryrosie, 15:47z, 11-10-01
- RE: Right Click disabled?,Ben Chiu, 18:53z, 11-10-01
- RE: Right Click disabled?,Mike_Greenwood, 20:26z, 11-10-01
- RE: Right Click disabled?,jerryrosie, 21:06z, 11-11-01
- RE: Right Click disabled?,Ben Chiu, 19:11z, 11-04-01
- RE: Right Click disabled?,vgbaron, 20:32z, 11-04-01
- RE: Right Click disabled?,vgbaron, 20:55z, 11-06-01
- RE: Right Click disabled?,Ben Chiu, 21:17z, 11-06-01
"RE: Right Click disabled?"
Posted by Ben Chiu on 11-02-01 at 03:48z
____________________
Greetings Vic:
You can jump to the message list (or the forum list) from the menu at the bottom of every message page.
Welcome to the VPC!
Posted by vgbaron on 11-03-01 at 01:41z
Hi Ben - OK, I see it now. It's a little tiny for my old eyes
BTW, is there or will there be a way to quote in a reply?
Thanx,
Posted by Ben Chiu on 11-03-01 at 02:42z
Greetings Vic:
What I do now is highlight the text and press Ctl+C, to past I use Shift+Ins.
We don't have the ability to autoquote a reply, but perhaps we can work that in eventually.
Posted by Madape on 11-04-01 at 23:47z
____________________Ben
I find it slightly easier to use Ctrl + V to paste, because its right next to C key.
Sam
Posted by Ben Chiu on 11-10-01 at 08:25z
Greetings again Vic: >We don't have the ability to autoquote a reply, but
Your wish is our command. The message board now has autoquote!
Posted by jerryrosie on 11-10-01 at 15:47z
>autoquote!
>Ben Just had to try this out
. I see that it quotes the whole message. Any possibility of having it auto-quote only the portion that is highlighted - similar to ctr+c/crtl+v exercise without having to punch all those keys?
Cheers, Jerry
Posted by Ben Chiu on 11-10-01 at 18:53z
>only the portion that is highlighted - similar to >color=red]ctr+c/crtl+v exercise without
>having to punch all those keys? Tough crowd...
Seriously, I'm not sure. We'll look into it.
Posted by Mike_Greenwood on 11-10-01 at 20:26z
>>Tough crowd... <<Hey, you asked for it!
Posted by jerryrosie on 11-11-01 at 21:06z
>>only the portion that is highlighted - similar to >>color=red]ctr+c/crtl+v exercise without
>Tough crowd...
>Ben Thanks!! Note that the auto-quote quotes the "raw" HTML command and not the results of the command
Cheers, Jerry
Posted by Ben Chiu on 11-04-01 at 19:11z
>>OK, I see it now. It's a little tiny for my old eyes<<
Greetings again, Vic:
I forgot to mention that the Conference and forum names displayed on the message table title bar (upper left corner of the table in messages view) are links as well. They'll do the same things that the mini link versions within and at the end of the page will do.
Posted by vgbaron on 11-04-01 at 20:32z
<<I forgot to mention that the Conference and forum names displayed on the message table title bar (upper left corner of the table in messages view) are links as well. >>Got it! That makes it a bit easier. Thanx, Ben.
Posted by vgbaron on 11-06-01 at 20:55z
Ben - Just FYI - I tried three different ways to go back to the topics while reading a message. Clicking the links at the top/bottom of the list and using the ALT-LEFTARROW combo. Using IE5.5 sp2 - the clicks resulted in the page being reloaded, taking several seconds. The key combo was almost instantaneous (probably using cached page).
Obviously the key combo is the way to go.So far so good
Posted by Ben Chiu on 11-06-01 at 21:17z
Greetings Vic:
>>uing the ALT-LEFTARROW combo<<
Just FYI, you can also use BACKSPACE to do the same thing.
>>The key combo was almost instantaneous (probably using cached page).<<
Yep, that's what it's doing.
>>So far so good<<
Great! Thanks for sticking with it. There are many things that aren't going to be the same as CiS here, but it's the people that count, right?
Right now we're still working on functionality (getting everything to working as intended), but once that's done, we'll start on the ergonomics and address the issues such as autoquoting, etc.. It may take a while longer than we'd like, but rest assured we'll get there.
Best!
