Thread Number: 282
"FS2002 Multiplayer Ports !!!"
Posted by maveco on 11-29-05 at 03:06z
Hi fellows!!
I have a problem. I've installed a router in my home and now I cant fly online. A friend create a server and send me the ip but I only can see my own computer lan ip. Some guys have told me that I must 'open' some ports on the router that the FS 2002 needs. I saw at FAQ page, some ports but I think it is for FS 2000.Do you fellows can help me and tell me for sure the ports that que FS2002 (not 2000, ou 2004), FS2002 needs so I can fly online multiplayer???
Its is VERY important to me.
Sorry about my english, Im typing from Brazil and Im still trying to improve it!
best regards!!!!
Cap. DanieL
- RE: FS2002 Multiplayer Ports !!!,Ben_Chiu, 05:40z, 11-29-05
- RE: FS2002 Multiplayer Ports !!!,maveco, 16:10z, 11-29-05
- RE: FS2002 Multiplayer Ports !!!,Ben_Chiu, 20:04z, 11-29-05
- RE: FS2002 Multiplayer Ports !!!,maveco, 02:11z, 11-30-05
"RE: FS2002 Multiplayer Ports !!!"
Posted by Ben_Chiu on 11-29-05 at 05:40z
Hi Daniel:Have a look at the our FAQ's. The ports are listed there (probably under the Flight Terminal).
Posted by maveco on 11-29-05 at 16:10z
Hi Ben.Thanks for your help, but like I said, I saw at FAQ page, some ports but I think it is for FS 2000, and I need to know the ports for the FS2002, not 2000 .
can you or some other fellow help me???
best regards !!!
Cap. DanieL
Posted by Ben_Chiu on 11-29-05 at 20:04z
Hi Daniel:As far as I know the ports in FS2002 are the same as FS2000. Check to see if you can ping your machine from outside. If not, I seem to recall that some firewalls have a "privacy" feature that disables the ability to receive pings. Without that ability, you won't be able to connect. I know there was a problem with that setting for other programs such as Chat and it interfered with FS as well.
Posted by maveco on 11-30-05 at 02:11z
Hey Ben!Okay, I'll try to open these ports, and check the firewall. . . hope that the ports are the same!
thanks for the help and fast answer!
beste regards!!
Cap. Daniel
