Thread Number: 243
"VoiceCOM for FS2004 version 1.0"
Posted by Admin on 07-25-03 at 17:57z
Even though FlightSim 2004 hasn't been released yet, we've got VoiceCOM 1.0 for Flight Simulator 2004 available for download.
This install will add FlightAdventures VoiceCOM to your installation of Microsoft Flight Simulator 2004, and will also keep FS2K4 from starting in your default flight when flying multiplayer mode if you have the Show opening screen option enabled in the Options: Settings: General configuration box.
VoiceCOM allows you to switch Roger Wilco channels from withing Flight Simulator, and therefore requires Roger Wilco to be installed on your system, and an Internet connection is required to be able to communicate with other pilots.
You can download Roger Wilco from the FlightAdventures Virtual Pilot Center at http://www.flightadventures.com in the file download section. We strongly recommend version mk.1c
Flight Simualator 2004 must be shut down before installing this add-on.
This add-on ****MUST BE INSTALLED IN YOUR FS2004 FOLDER**** to install correctly.
Download the file:
http://files.flightadventures.com/dl.pl?VoiceComFS2k4setup.exe
