VoiceCOM 1.0 for Flight Simulator 2002 is now available for download.This install will add FlightAdventures VoiceCOM to your installation of Microsoft Flight Simulator 2002, and will keep FS2K2 from starting in your default flight when flying multiplayer mode if you have the Show opening screen option enabled in the Options: Settings: General configuration box.
VoiceCOM allows you to switch Roger Wilco channels from withing Flight Simulator, and therefore requires Roger Wilco to be installed on your system, and an Internet connection is required to be able to communicate with other pilots.
You can download Roger Wilco from the FlightAdventures Virtual Pilot Center at http://www.flightadventures.com in the file download section. We strongly recommend version mk.1c
Flight Simualator 2002 must be shut down before installing this add-on.
This add-on ****MUST BE INSTALLED IN YOUR FS2002 FOLDER**** to install correctly.
Download the file:
http://files.flightadventures.com/dl.pl?VoiceComFS2k2setup.exe
Hi Ben, please clarify :
>mk.1c
Now I read :
>We encourage everyone to download and install Roger Wilco >2.5 (in our downloads area) for their flights.Is this the same version of RW?
Hi Emile:> Now I read :
> Is this the same version of RW?No, it's not. mk.1c is the version to get. Where did you read 2.5? Must have been written by one of us that missed a memo somewhere.
Just FYI, mk1c was the last version that didn't include spyware.
Hello Ben,
>a memo somewhere.
>spyware.I found the mention to 2.5 in :
"VPC Flight Terminal Persistent World Flight Supports FS2004 enters testing
The VPC Flight Terminal Persistent World Flight is testing supports for Flight Sim 2002 and Flight Sim 2004 pilots in the same session.
Prior to this addition of the Persistent World Flight different versions of Flight Simulator could not interact. Other limitations were when the host of the sesion left the flight no other pilots would be able to join the session. The VPC Persistent World Flight eliminates this problem while adding several new features that enhance the online flying experience.
Utilizing FSHost Technology, some of the new features include:
- Text reports of pilot locations and positions
- Text reports of aircraft being flown in the session
- The ability to file flight plans which can be viewed by other pilots and ATC controllers
The VPC Flight Terminal allows pilots to join existing flights or create your own with friends and soon-to-be friends in the virtual skies over the VPC.The VPC Flight Rooms use ActiveX technolgoy and support FS98, FS2000, FS2002, Combat Flight Simulator, most every DirectX/DirectPlay game out there, and now Flight Simulator 2004.
Featuring greatly simplified processes of creating and joining multiplayer flights (less complicated than the Zone), other include:
- Greater pilot capacity
- One click launch
- The ability to join flights in progress (no IP memorization required!)
- The Flight Terminal will automatically recognize your VPC cookie (you only log on to the VPC once to enjoy all VPC services)
- Dedicated Flight Rooms for specific simsOther notes:
- Download or read
http://www.flightadventures.com/docs/VPCFTI.htm for detailed information about how to use the Flight Terminal Information. If you require further assistance or information then please don't hesitate to ask.--> We encourage everyone to download and install Roger
-->Wilco 2.5 (in our downloads area) for their flights.This is why I was confused
Ah, OK, we'll fix that. Sorry about the confusion.
