Greetings:Now that we're holding multiplayer ATC sessions in the Flight Terminal, we've reached the point where we need to start using multiple frequencies.
- VoiceCOM brings up a mini menu which you can use to select the main frequencies we use here in the Central Coast. This works fine for folks flying in Windowed mode. However, it may cause some odd problems with FS when run in full-screen mode. Problems vary from installation to installation and system to system, so you'll need to try it to see how it works yourself. We're working on add-on module to run in FS that will work as a panel to switch RW frequencies. (More on that when we start testing.)
Just as in the real world, please remember when using VoiceCOM/RW, listen before transmitting, think before speaking, and use another non-ATC channel for chit chat.
Greetings Emile:> OK, I will test this weekend.
Sorry for the confusion. The new RW "switcher" isn't available for testing yet.
> BTW some improvements in the "Status" display?
Yes, in the Persistent Flight World. We still have an issue with auto launched games and positions, but we're working on it.
Best!
