Greetings!We've converted the Flight Terminal to our new DirectX VPC Launcher. The new launcher eliminates a couple of steps required by the previous .exe version. This latest advance will make it easier to fly from the Flight Terminal.
If you haven't tried flying online yet, now's a great time to try.
Because we'll no longer be supporting the former, user-installed version of Fly Now! (the one that you downloaded and installed using an install) you should remove it from your system (use Add/Remove Programs from Control Panel).
