Thread Number: 181
"Flight Terminal Flight 15 warning"
Posted by Ben_Chiu on 07-16-02 at 04:52z
Greetings:Just a heads up to let everyone know what Flight 15 is being used to test a new ActiveX-based VPC Launcher. The benefits of this new technology will be smaller program size, automatic download, automatic install, automatic updates, lower susceptibility to bad browser configuration/installs, and better integration to the VPC system.
- RE: Flight Terminal Flight 15 warning,RobertVA, 03:45z, 07-17-02
- RE: Flight Terminal Flight 15 warni...,Ben_Chiu, 06:24z, 07-17-02
- RE: Flight Terminal Flight 15 warning,Emile, 06:14z, 07-17-02
- RE: Flight Terminal Flight 15 warning,Emile, 19:42z, 07-17-02
- RE: Flight Terminal Flight 15 warni...,Ben_Chiu, 19:47z, 07-17-02
- RE: Flight Terminal Flight 15 warni...,Emile, 18:58z, 07-19-02
- RE: Flight Terminal Flight 15 warni...,Ben_Chiu, 23:06z, 07-19-02
- RE: Flight Terminal Flight 15 warni...,Emile, 06:33z, 07-20-02
"RE: Flight Terminal Flight 15 warning"
Posted by RobertVA on 07-17-02 at 03:45z
Just let us know when you need volunteers for the beta test!
"RE: Flight Terminal Flight 15 warni..."
Posted by Ben_Chiu on 07-17-02 at 06:24z
Greetings Robert:> Just let us know when you need volunteers for the beta test!
We've made a couple of last minute changes, but you're welcome to try out Flight 15 at any time. It should work properly, but of course let us know if you encounter any problems. Please note that this new version of Fly Now! is an ActiveX control, so it'll take a couple of minutes to download the first time you launch it and anytime we update the application. Also note that if any warning boxes appear, you need to click Yes.
A new feature we added to this new version is Fly Now! will now automatically shut down when you exit the Flight.
Just for everyone's information, we're currently working on the next generation of ACARS, but once that's up and running, we'll come back to the Flight Terminal and eliminate all of the refreshing that goes on and simplify the process some more. But one step at a time...
Posted by Emile on 07-17-02 at 06:14z
Hello,
For your information I did install the latest DirectX 8.1B, no problems found
Posted by Emile on 07-17-02 at 19:42z
I just did a flight on Flight 15, no problems at all
Posted by Ben_Chiu on 07-17-02 at 19:47z
> I just did a flight on Flight 15, no problems at allVery good! Thanks, Emile!
Unless we find someone has a problem in the next few days, we'll move the rest of the Flights to the new launcher. Everyone will then be able to remove the old launcher from their systems--but please wait until we give the word before doing that.
Posted by Emile on 07-19-02 at 18:58z
Hello ,
I did try to launch Flight 15
After selecting "Fly now!" I did receive a popup box with following error message
"Vlx
Invalid IP address
Aborting"
Tried twice same resultI went to Flight 1
Posted by Ben_Chiu on 07-19-02 at 23:06z
Greetings Emile:> I did try to launch Flight 15
> error message
> "Vlx
> Invalid IP address
> Aborting"
Which game did you select from Fly Now!? Were you in Host mode or Join mode (It'll say Host or Joining session). You might see that type of error if you're the only one in the Flight, but trying to Join a session. Please note what Fly Now! mode is indicated if it happens again.
> I went to Flight 1
Did Flight 1 work for you?
Posted by Emile on 07-20-02 at 06:33z
Hello Ben,
I did try again this morning, I had NO problem, in my opinion I did the same than yesterday (FS2002, alone no join) , I will note the messages and responses next time
Have a nice day
Registered to: Emile E. De Mesmaeker
