Thread Number: 168
Original Message"Netgear RT-311 ro RT-314 router setup for the Flight Terminal"
Posted by craiggresham on 04-29-02 at 18:12z
Settings for the Netgear RT-311 and/or the RT-314 router. The first thing you need to do is get the firmware version 3.25. Now assuming you already have it configured so you can surf the internet. After configering it for the web click start, run in run box type in “telnet 192.168.0.1” (or replace the IP address of your router if different than the default address) and click OK a dialog box will appear asking for a password. Enter your password for your router (factory default is “1234”) that will get you to the main menu. From here type in menu option “15” and press enter. You should now see the SVA Server Setup menu. On rule number 1 enter the IP address of the computer you will be using the flight simulator on. After entering the address press enter until the main menu comes up again. Type in 99 and press enter then close the blank dialog box. You should now be set up to use the Flight Terminal Simulator Launcher. Included with this post is screenshot of the SVA Server Setup menu.
