Thread Number: 125
"VPC Beta error message received"
Posted by Emile on 01-25-02 at 14:25z
Hi , on the Forums page; when i "click" the 'check the VPC flight room lobby' link ,I receive on bottom of the page "error on page"
- RE: VPC Beta error message received,Ben Chiu, 17:43z, 01-25-02
- RE: VPC Beta error message received,James, 20:22z, 01-25-02
- RE: VPC Beta error message received,James, 20:29z, 01-25-02
- RE: VPC Beta error message received,Stephen, 20:36z, 01-25-02
- RE: VPC Beta error message received,James, 12:09z, 01-26-02
- RE: VPC Beta error message received,Emile, 06:49z, 01-30-02
- RE: VPC Beta error message received,Emile, 06:53z, 01-30-02
- RE: VPC Beta error message received,Ben Chiu, 07:07z, 01-30-02
- RE: VPC Beta error message received,Emile, 08:41z, 01-30-02
- RE: VPC Beta error message received,Ben Chiu, 20:01z, 01-30-02
- RE: VPC Beta error message received,Emile, 20:27z, 01-30-02
- RE: VPC Beta error message received,Ben Chiu, 20:45z, 01-30-02
- RE: VPC Beta error message received,Emile, 11:01z, 01-31-02
- RE: VPC Beta error message received,Ben Chiu, 19:01z, 01-31-02
- RE: VPC Beta error message received,jerryrosie, 15:03z, 01-30-02
"RE: VPC Beta error message received"
Posted by Ben Chiu on 01-25-02 at 17:43z
>"error on page" It sounds like you're arriving to the message board from a bookmark rather than from the main VPC page. We've tied the link in question to the main VPC page (e.g. you can't login to the Lobby without having the main VPC page open) to eliminate multiple logins.
Posted by James on 01-25-02 at 20:22z
Hi Ben,I think I have the problem mentioned <s>. Once logged in on the main page select Flight Rooms, it starts up but pops up an error on page. Select a flight room though and another error box pops up.
" Command execution of Fly_Now! has been disallowed by your browser's security level settings. Please add www.FlightAdventures.com to your Trusted Site list."
Now go to the relevant tab in your browser and add the link "www.FlightAdventures.com" on klicking OK a dialog box pops up stating you have to place "https:/" to the URL.
Can't remember what happens then but you still can't log into a flight room.
Posted by James on 01-25-02 at 20:29z
Just looked at the error box again and looked into the details section and it reports,Line 104
Char 32
Error Object doesn't support this property or method
Code 0
URL http://www.flightadventures.com/flight_main.shtml
Posted by Stephen on 01-25-02 at 20:36z
You can add non-HTTPS URLs to MSIE's Trusted Sites list by unticking the box "Require server verification for all sites in this zone" which is found on the Trusted Sites list window.-Stephen.
Posted by James on 01-26-02 at 12:09z
Hi Stephen,Rgr, will take another look at it and try it out
Posted by Emile on 01-30-02 at 06:49z
Good morning,
I tried the "updated" link found this morning.
In the new window after input my name and password I receive a green colour message at the bottom of the black box following message "Connecting to servers".
I waited several minutes without receiving a response
Posted by Emile on 01-30-02 at 06:53z
Later I did try with "guest" as suggested and I had the same result "Connecting to servers..." but never an answer
Have a nice day
Posted by Ben Chiu on 01-30-02 at 07:07z
>same result "Connecting to servers..." but never an answer Anyone else have a problem?
Emile, which browser are you using?
Posted by Emile on 01-30-02 at 08:41z
I tryed from the office and we run Internet Explorer 5.50.4522.1800IC
Posted by Ben Chiu on 01-30-02 at 20:01z
>5.50.4522.1800IC Did it ever work for you before (e.g. using the older link and entering from the main VPC page?). Does anything else here at the VPC not work? Does it work from your home computer?
The only thing I can think of is your office computer is blocking the port we use to access the VPC Flight Server (port 6112).
Posted by Emile on 01-30-02 at 20:27z
I tryed from home, it works except that my login is rejected only the "Guest" login is accepted.
I think you are right at the office the Firewall must block the port, I will check with some System Engineer tomorrow.
Thanks Ben
Posted by Ben Chiu on 01-30-02 at 20:45z
>rejected only the "Guest" login is accepted. That's normal (at least for now). The Flight Server database is not linked to the main VPC database yet. You'll need to use the FlyNow! client to create an account first (we recommend that you use your same nick and password to simplify things). Once your account has been created, you'll be able to use your nick and password to enter the Flight Server Lobby.
Posted by Emile on 01-31-02 at 11:01z
Hello, I confirm that port is blocked at the office.
Thanks, I will access from home
Have a nice day
Emile EBBR
Posted by Ben Chiu on 01-31-02 at 19:01z
>Thanks, I will access from home Greetings Emile:
Thanks for the update. You'll have to get the network admin to open up the port or you'll have to join multiplayer flights via IP while you're at work!
Posted by jerryrosie on 01-30-02 at 15:03z
>>Anyone else have a problem?<<Nope.....
Cheers, Jerry (N94)
