Forum: DCForumID11
Thread Number: 38
"FlightAdventures VoiceCom FS2004"
Posted by Mike_Greenwood on 07-30-03 at 23:19z
This install will add FlightAdventures VoiceCOM to your installation of
Microsoft Flight Simulator 2004, and will also keep FS2K4 from starting
in your default flight when flying multiplayer mode if you have the Show
opening screen option enabled in the Options: Settings: General
configuration box.
VoiceCOM allows you to switch Roger Wilco channels from withing Flight
Simulator, and therefore requires Roger Wilco to be installed on your
system, and an Internet connection is required to be able to communicate
with other pilots.
You can download Roger Wilco from the FlightAdventures Virtual Pilot
Center at http://www.flightadventures.com in the file download section.
We strongly recommend version mk.1c
Flight Simualator 2004 must be shut down before installing this add-on.
This add-on ****MUST BE INSTALLED IN YOUR FS2004 FOLDER**** to install
correctly.
http://files.flightadventures.com/dl.pl?VoiceComFS2k4setup.exe
FlightAdventures Administration and Staff
