Forum: DCForumID11
Thread Number: 36
"FlightSim Yoke LE USB Config Utility"
Posted by Mike_Greenwood on 07-30-03 at 23:11z
This FlightAdventures install will configure your FlightSim Yoke LE USB
and USB Rudder Pedals to the FlightAdventures standard axes and button
configuration for Microsoft Flight Simulator 2004. Because the most
realistic controller operation can only be obtained through linear
controller operation, this utility also installs the FlightAdventures
FS2K4/XP Linear Controller utility as well.
http://files.flightadventures.com/dl.pl?FS2K4XPFlightSimYokeLEUSBsetup.exe
Notes:
- This utility has only been tested on Windows XP systems.
- Flight Simualator 2004 must be shut down before installing this
add-on.
- You must have FS2004 installed for this utility to be of any use!
FlightAdventures Administration and Staff
http://www.flightadventures.com
