Thread Number: 865
"Multiplayer Flight Ideas"
Posted by RobertVA on 06-03-04 at 23:59z
Chicago Ohare to Detroit Metro Wayne Co. 211 nm IFR in jet transport (Boeing 737/747/777). Distance does not include arrival pattern, which may add a few dozen miles.Meadows CA to San Luis Co. Rgnl. 85 nm VFR in Cessna 172 or similar.
Ideas not used this week can be carried over to future weeks.
- RE: Multiplayer Flight Ideas,andor, 00:25z, 06-04-04
- RE: Multiplayer Flight Ideas,RobertVA, 21:24z, 07-31-04
- RE: Multiplayer Flight Ideas,vgbaron, 18:44z, 08-01-04
- RE: Multiplayer Flight Ideas,andor, 06:20z, 08-02-04
- RE: Multiplayer Flight Ideas,RobertVA, 07:50z, 08-02-04
- RE: Multiplayer Flight Ideas,Ben_Chiu, 17:22z, 08-02-04
- RE: Multiplayer Flight Ideas,RobertVA, 07:44z, 08-03-04
- RE: Multiplayer Flight Ideas,Ben_Chiu, 19:50z, 08-05-04
- RE: Multiplayer Flight Ideas,vgbaron, 20:41z, 08-05-04
- RE: Multiplayer Flight Ideas,RobertVA, 18:14z, 06-12-04
- RE: Multiplayer Flight Ideas,Ben_Chiu, 01:56z, 06-13-04
- RE: Multiplayer Flight Ideas,RobertVA, 20:50z, 06-13-04
- RE: Multiplayer Flight Ideas,vgbaron, 16:08z, 06-14-04
- RE: Multiplayer Flight Ideas,andor, 02:01z, 06-18-04
- RE: Multiplayer Flight Ideas,DylanK, 06:13z, 06-22-04
- RE: Multiplayer Flight Ideas,Ben_Chiu, 18:39z, 06-22-04
- RE: Multiplayer Flight Ideas,RobertVA, 05:09z, 08-17-04
- RE: Multiplayer Flight Ideas,andor, 05:18z, 08-17-04
- RE: Multiplayer Flight Ideas,RobertVA, 07:41z, 08-17-04
- Toronto Downsview to Niagara Falls Intl.,RobertVA, 23:40z, 08-25-04
- RE: Multiplayer Flight Ideas,andor, 00:04z, 08-28-04
- RE: Multiplayer Flight Ideas,RobertVA, 21:17z, 08-28-04
- RE: Multiplayer Flight Ideas,Ben_Chiu, 19:23z, 08-30-04
- RE: Multiplayer Flight Ideas,RobertVA, 19:04z, 08-31-04
- RE: Multiplayer Flight Ideas,andor, 02:12z, 09-02-04
- RE: Multiplayer Flight Ideas,RobertVA, 07:25z, 09-09-04
- RE: Multiplayer Flight Ideas,RobertVA, 08:20z, 09-09-04
- RE: Multiplayer Flight Ideas,RobertVA, 23:07z, 10-15-04
"RE: Multiplayer Flight Ideas"
Posted by andor on 06-04-04 at 00:25z
G,day Robert,
KORD - KDTW sound OK by me Robert, (option of the Lear ??)
The big guys take too long to pull up
Will abide by majority choice.
Posted by RobertVA on 07-31-04 at 21:24z
I'm proposeing a glider flight for Aug 8 landing on KSBP runway 7.If the default flight planner is used to generate a plan through the VOR west of the airport and the intersection at the rwy 7 threshold, the GPS will help get on the proper side of the field, where circling and the speed brake can be used to establish a serviceable final.
Lets discuss if we want to "just say no" to the "relocate aircraft" popup associated with the flight plan or allow the relocation and slew airborne from a nearby airport. Starting from over Paso Robles at 9,000 ft it took me about 40 minutes to glide to San Luis Obispo with enough altitude for several circles to the west of KSBP before landing. If we say no to the relocation we can fly circles over KSBP before we use the GPS to help line up for landing.
I had to be carefull about keeping my nose up to clear the ridge betwen two airports. With a bit of practice it looks like it would be possible to start at 7,500 ft.
Posted by vgbaron on 08-01-04 at 18:44z
Sounds intriguing Robert - I'm for it whichever way we go.Vic
Posted by andor on 08-02-04 at 06:20z
Also sounds good to me Robert, my personal choice would be for just nominating a departure airport, slew to agreed Alt- head west or whichever.. use tower as landmark.. but then I am a confirmed VFR rules guy
I tried it from Bogdan (5CL1) slewed to 3500' and did not make the ridge, a point noted was that after slew I could not get FS to accept any wind direction and force. I fed in a SW,ly 8knots, hoping to get some lift off the ridge but there was nothing showing in the Shift+Z.
Anyway sounds like fun,
Posted by RobertVA on 08-02-04 at 07:50z
I'm not sure the simulator normally models air flow over and around terrain or scenery objets. I recall some earlier versions would only produce "ridge lift" in special areas designated during design of the scenery. I think some versions simulated ridge lift in an area North of San Francisco Bay and near part of the Oahu coast. Others may have more infomation than I though.I don't recall any mention of Microsoft Flight Simulator modeling thermals, but I suspect a creative scenery designer could fake that as well. Only mention I recall of a flight simulation modeling thermals was about Flight Unlimited.
Posted by Ben_Chiu on 08-02-04 at 17:22z
If you guys want some wind, let me know from which direction and speed and we'll arrange it. If you'd like a typical wind in this area (generally 300-310 from 10-25 knots).Ben
Posted by RobertVA on 08-03-04 at 07:44z
Judging from Andy's test we might not get any ridge lift from a wind. I wonder if 8 kts is enough though. The simulator would have to constantly compare the slope of the point under the plane and the slope's direction to the wind speed and direction to even approach simulating the effect in all the ridges in the scenery mesh. I couldn't find any ridge lift flights in the "Select a Flight" system either.I think we'll just have to glide without ridge or themal soaring. If the server generates winds out of the NW we can use runway 25 instead of 7.
Posted by Ben_Chiu on 08-05-04 at 19:50z
> flights in the "Select a Flight" system either.Bummer.
I don't know why I didn't think of it earlier, but in the old days, we used to simulate a tow plane for glider flights by making use of Ctl + Shift + F. One player would fly a tow plane and the glider pilot would would use CSF mode until they wanted to be release. What I can do for the flight on Saturday is park a 172 in orbit over the PRB VOR and we could launch off of that. What do you think?
Posted by vgbaron on 08-05-04 at 20:41z
Sounds interesting to me.Why not give it a shot.
Posted by RobertVA on 06-12-04 at 18:14z
Chicago Ohare to Detroit Metro was used June 6Remaining proposal Cessna 172 VFR Meadows CA to San Luis Obispo CA for June 13. I estimate 55 minutes enroute. While not previously mentioned, pilots may continue to select their individual desired season and time of day.
Any ideas for June 20 or later weeks?
Posted by Ben_Chiu on 06-13-04 at 01:56z
>Any ideas for June 20 or later weeks? I think Vic will be back for the flight next week. How about we do Phoenix to Las Vegas at dusk so we land at night?
Posted by RobertVA on 06-13-04 at 20:50z
Would be 237 nm useing DRK and BLD VORs (J92) and BLD approach to KLAS runway 25R (HAWKO & CONDY). The FS 2004 planner ETE 30 minutes and 3,400 lb fuel consumption for the 737.Robert
Posted by vgbaron on 06-14-04 at 16:08z
Sounds good to me!Vic
Posted by andor on 06-18-04 at 02:01z
DITTO
Posted by DylanK on 06-22-04 at 06:13z
If you're interested, I have some photos from a flight a couple months ago from BFL to SBP (actual) along with routing and the flight plan.
Posted by Ben_Chiu on 06-22-04 at 18:39z
>routing and the flight plan. Hey Dylan:
Sure, send me a couple with a write up and we'll post them in the Adventure Logs.
Posted by RobertVA on 08-17-04 at 05:09z
Andy's Proposal for August 22, 2004:Springtime in Yosemite Nat. Park (Canyon) J
Objective:- To fly VFR to Posn Alpha , descend and follow canyon floor at altitude of choice (got Yogi,s approval J ) Climb out to Posn Beta and immediately land in the paddock or on the lake.
Depart. Airport Mariposa-Yosemite ID o68 (Oscar)
Alt. 2250
R/W. 08/26 (3310ft)
Fly Hdg.043* dist. 15.5’ to
Position Alpha (Lat 37*40.7 Long 119*47.3 Alt 6500) Can use Shift + Z if forgot the stopwatch J -- then to Hdg 090* approx.
Suggest more Northerly course (020*) to intersect Lat 37*40 then "run your easting down J " to Long 119*47 as canyon difficult to pick out. (Look for river & tracks)
Descend into canyon (3500’) and follow tracks and river. On reaching a fork in the canyon ( round hill on the skyline ahead) take left fork over a small lake, commence a steep climb to exit at
Position Beta (Lat37*47.4 Long119*29.3) Alt 8800 Immediately after the Exit position there is a fairly clear level paddock :-
Lat 37*49.4 Long 119*28.4 Approach. O2/200 Alt. 8202
After the paddock at Northern end is a sizable lake.
Approach Lake 03/210* Alt 8202’ The Caravan ( Amphib) did the climb out of the canyon easily
Used the Baron. (No problem) C152 (just made climb out of canyon)
Warning : climb out of the canyon is very steep. At the crest keep to the left for line up with the paddock.
ETE in the 152 is 38minutes.
Recommend cliff textures from www.aussim.com.au (Cliffs.zip 2.55mb)
Posted by andor on 08-17-04 at 05:18z
G,day guys,Talk about FAST !!
Many thanks Robert, I am just about to copy and paste into a post (new thread) the same flight particulars , working on Ben,s advice to try Cut/Copy/ Paste etc. Will give it a go, again many thanks,
Posted by RobertVA on 08-17-04 at 07:41z
Position Alpha is very close to the ELCAP Intersection over El Portal CAThe canyon is Yosemite Valley containing the Merced River. We will pass El Capitan (37° 44.15'N 119° 37.95'W 7569 ft) and Yosemite Falls (37° 45.45'N 119° 35.80'W) both to our left.
The left turn is just before Half Dome (8842 ft) and leads over Mirror Lake. The valley to the right is the Little Yosemite Valley containing the upper portion of the Merced River.
Position Beta is in Tenaya Canyon containing Tenaya Creek.
The lake at 37° 49.64'N 119° 27.95'W is Tenaya Lake
Most of this information is from Microsoft Encarta Interactive Word Atlas 2001 or DeLorme Street Atlas USA 7. Intersection identification from Flight Simulator 2004 Map.
"Toronto Downsview to Niagara Falls Intl."
Posted by RobertVA on 08-25-04 at 23:40z
After takeoff from Downsview/CYZD turn over Toronto/YYZ VOR to follow V-164 to overfly Bassett Field/61NY (note turn at BULGE Int to a 123º course towards, but not to, Buffalo/BUF VOR ) then to KATHI Int./ADF and landing on KIAG Rwy 28.I haven't made my own ETE calculations, but FS 2004 thinks the DC-3 would take 40 minutes to fly that 68 nm. route.
Check the fix in the Flight Simulator Adventure Logs if you plan to overfly the falls, but be carefull about the restricted airspace!
Posted by andor on 08-28-04 at 00:04z
Rgr Robert... answers my query in your 'US Carriers " post
See you in CYZD
Posted by RobertVA on 08-28-04 at 21:17z
There's a suggestion on the table to simulate some carrier traps on the Kitty Hawk (or Constellation if flying FS 2002) for the September 5 multiplayer. The ship is located a few miles outside San Francisco Bay. I figure we can fly to the vicinity of the ship and enter a left hand pattern, which I gather isn't to dissimilar to what US Navy pilots use (except maybe length of downwind and final)Does anyone have suggestions about a departure point? Should we set up some winds to reduce our ground speed at touchdown? Let's discuss in the regularly scheduled Pilot Lounge chats as well as here.
I'll be flying one of the smaller single engine planes or a helicopter for this one.
Posted by Ben_Chiu on 08-30-04 at 19:23z
Greetings Robert:> I figure we can fly to the vicinity of the ship and enter a left hand
My understanding is military patterns are more of racetrack (oval rather than rectangular) shape, and yes, left traffic.
> Does anyone have suggestion about a departure point?
How far out to sea is the carrier? Perhaps Moffett would be nice (so we can see the Golden Gate and downtown on the way out).
> Should we set up
Which direction is the carrier steaming? Here's an interesting question: I wonder if the carriers change direction based on the wind direction as they do in real life? They never have in the past, but I would think they could be coded like the windsocks in FS.
Let me know which direction and speed you want and I'll see what we can do.
Posted by RobertVA on 08-31-04 at 19:04z
The position of CV-63 Kitty Hawk in FS 2004 is the same as CV-64 Constellation in FS 2002 as listed in the other thread. That's about 8 miles SSW magnetic of Saulsalito VOR (per GPS readout). The ship heading apears to be approximately 75°. The ship's heading does not appear to respond to changing the direction of 16 mile winds in the simulator.Departing from Moffett Federal (KNUQ) to the carrier via VOR SFO, int. KUWAF (West of Alcatraz) and VOR SAU would be approximately 47 nm. That route would cross the San Francisco Class B airspace though. I don't have terminal area charts to determine if there are any GA corridors across the Class A or the adjacent Oakland Class C airpace. A westward route under the outer portion of the San Francisco Airspace would be significantly less interesting. We might just want to request clearance to cross over SFO a few thousand feet above the field.
We can discuss the merits of wind aiding the landing and impeding the westbound leg in the pilot lounge chats.
Posted by andor on 09-02-04 at 02:12z
G,day Robert (guys),
Missed Wed. chat
, sounds good to me though I find the CV 63 in FS9 very disappointing , very little detail of the carrier.
I have just downloaded the CAR2004a.zip file from FlightSim, eighteen carriers positioned throughout the world. Great detail, even to "slewing" onto the hangar deck.(I reckon we could all fit into it
What really put the icing on the cake is the CVN68 USS Nimitz is stationed just off the coast from TAREE !!
Well worth the download 4.76Mb.
Regards till Friday,
Posted by RobertVA on 09-09-04 at 07:25z
Grand Manan Maine to Bangor Maine:92 nm within sight of Maine coast.
Inverness Scotland to North Connel Scotland:
78 nm along a Scottish valley. Would be a good flight for the Piper J3. I plan to stick to VFR pilotage for the navigation in this flight.
Moshi Tanzania to Loitokitok Kenya:
Estimated 50 nm. See something most people don't associate with Africa. I'll have to hand edit the flight plan to get the exact milage, as there are few intersections in the area for the built in planner. Will be departing towards Mtito Andea (MTA) VOR on 052° heading, but will turn off about halfway to the beacon. May use 41 mile DME arc to the 251 radial.
As always other ideas are welcome.
Posted by RobertVA on 09-09-04 at 08:20z
Whoops! further researh indicates Grand Manan Island is considered part of New Brunswick Canada. The map in Flight Simulator doesn't indicate where the border is SE of St Andrews (about 25 sm NW of Grand Manan) and the border takes a SW turn to seperate the Island from Maine. I should have picked up on the airport code though.Robert
Posted by RobertVA on 10-15-04 at 23:07z
Fontanarossa at Catania Sicily to Reggo Calabria Italy60 nm, including vectors to landing on rwy 33
Most of route along east coast of Sicily near Mt Etna (listed at 3323 m/10,902 ft in Microsoft's Encarta Atlas)
Destination has an offset localiser
