Thread Number: 860
"Learjets"
Posted by Brown on 05-25-04 at 03:38z
How fast should a Learjet go over 10000ft.
"RE: Learjets"
Posted by Ben_Chiu on 05-25-04 at 19:04z
Hi Brown:
Are you asking about regulatory restrictions, structural limitations or typical flight speeds?
"RE: Learjets"
Posted by Brown on 05-25-04 at 23:42z
yes
"RE: Learjets"
Posted by Ben_Chiu on 05-26-04 at 01:08z
The regulations limit your airspeed to 250KIAS below 10,000'.
Above 10,000', the regs limit your airspeed to below Mach 1.0 over land (not that you can get that fast in this airplane).
Vmo for the Lear45 (I assume you're asking about the Learjet in FS) is 330 KIAS
Mmo and cruise speed is listed at Mach .81.
FYI, all of the V speeds are listed in each aircraft's kneeboard (press F10 from inside the cockpit and click the bottom button the right side of the kneeboard).
