Waypoint | Facility Name | Type | Frequency | Altitude | Heading | Distance | Est. Ground Speed | ETE |
KNUQ | Moffett | Apt. |
| 34 |
SNS | Salinas | VOR DME | 117.30 |
| 138 | 50 | 273 | 0:11 |
ROM | Priest | VOR | 110.00 |
| 109 | 55 | 300 | 0:11 |
KSBP | San Luis | Apt. |
| 209 | 163 | 55 | 174 | 0:19 |
Total |
| 159 |
| 0:41 |
Departure Airport Information | |||||||
KNUQ | Moffett Federal AFLD | ST/CO: CA | Unicom: 122.9 | CTAF: 119.55 | |||
LAT: N37 24.89 | LON: W122 2.97 | Elevation: 34 |
14L/32R | 9208 | 14L | ILS | 110.35 | 32R | ILS | 110.35 |
14R/32L | 8126 |
Destination Airport Information | |||||||
KSBP | San Luis Co Regl | ST/CO: CA | Unicom: 122.9 | CTAF: 124.00 | |||
LAT: N35 14.21 | LON W120 38.51 | Elevation: 209 |
11/29 | 5325 | 11 | ILS | 109.7 |
7/25 | 3175 |
Does this look interesting to the others?
Robert -OK by me but you might also want to look at a slightly longer flight - KTVL -> KSBP
KTVL -> HYP 176 13500 325 103sm
HYP -> PXN 196 13500 325 35.3
PXN -> ROM 156 13500 325 34.9
ROM -> PRB 161 9600 250 28.1
PRB -> CREPE 197 3900 150 21.8
CREPE -> KSBP 110 210 105 13.3total: 235mi :45 min
Either way is ok by me.
Does that estimated time enroute allow for:
- Limited to 250 knots from 6268 ft to 10,000 ft after departure
- Reduced speed during remainder of climb
- Not cruising at 100% throttle so other planes can catch up with the lead plane instead of being strung out in a line so far apart the trailing plane can't even see the multiplayer tag for the lead plane
At 300 kt cruise speed that might take almost a full hour, not allowing the additional time between different planes takeoffs and landings.
Is tha PRB waypoint part of a published approach? If a plane is flying VFR would there be any reason not to fly directly to CREPE from ROM? And if runway 29 is the active runway at KSBP wouldn't we substitute an intersection ESE of KSBP for CREPE too?
Is it normal in the real world to include aproach waypoints in the filed plight plan, or to refer to the onboard plates once the controler assigns the flight to an destination airport runway? With the new GPS units in FS 2004 we now have approach procedures available during flight, although I'm not sure to what extent the autopilot will respond to a procedure selected during the flight.
Sounds like some interesting scenery though.
> 1 Limited to 250 knots from 6268 ft to 10,000 ft after departure
>At 250kts the P-38 can climb at 2000 fpm
> 2 Reduced speed during remainder of climbsee above
> 3 Not cruising at 100% throttle so other planes can catch up with the
>If takeoff spacing is right - shouldn't be a problem assuming the pilot knows how to get the max out of the a/c - should easily cruise at 325kts
>About same as last flight - should take about an hour with no problems
>No, PRB was snuck in there to make it easier for tb to find his way <G>. For our flights, I am not concerned with the active rwy - time dictates we use 11.
>Might be fun to setup a flight sometime with the GPS but tb would have a problem.
I've set up approaches in flight on the GPS and the AP has handled it fine.
As I said, I don't care which one we fly -
Both Routes are interesting to me. Let's fly one February 15 and the other February 22! Lets get some other opinions as to which flight we do which week. Maybe later on we could start at Catalina! I can do a nice table of the Lake Tahoe route similar to the one I did for Moffett. I'm thinking the ATIS frequency might be a good addition after the field elevation, although the format I modeled the table after had Magnetic Variation in that location. FS 2004 doesn't seem to offer Mag. Var. in the map view popups, and the ones on the old Sublogic maps I have is probably out of date.I'm not familliar with all the tweaks involving things like fuel mixture and calculating the flights fuel burn to the point of having only a reasonable margin of safety reaching the destination. Both probably keep my speed down a bit. I would much prefer cruising at 85 to 95 percent and having a bit of throttle range so I can catch up if I start to fall behind. Being 5 miles from the tiny dot representing anouther plane isn't nearly as much fun as being about half a mile away and being able to see the shape of the plane and it bank turning at a waypoint. Using the Simulator rate or CTRL-SHIFT-F feels a bit like cheating. CTRL-SHIFT-F tends to result in a collision to often too.
> which week.I propose we go with your Feb 15th plan and then Vic's on the 22nd. Any seconds?
> Maybe later on we could start at Catalina!Sounds like fun!
> I can do a nice
> probably out of date.All that's really required is magnetic course or better yet, VOR radial. Once you have either of those magnetic variation is only of academic value.
> reasonable margin of safety reaching the destination.Without cruise charts, it's too much work trying to come up with good numbers.
> Both probably keep
> CTRL-SHIFT-F tends to result in a collision to often too.I flew the P-38 with the drop tanks last Sat and boy-o-boy, do those things create a lot of drag. I resorted to bypassing waypoints and flying direct to "keep up" with you guys!
I agree with Ben's post - lets fly yours this week and mine next. I wanted to go from Tahoe but it's just a bit too long for our time.Since this is a sim, the easiest way in this a/c to select the correct mixture is by ear. Start leaning out the mixture until the rpm just starts to drop, then increase a smidge. In a decent model, this will give you the best fuel consumption and the most power. This does not take into account any prop settings.
You should easily get 325kts out of the P-38 night model. If you want to get a wee bit more, fly with half the fuel load. You can always use WEP ( war emergency power ) for a few minutes to speed up.
I think that part of the fun of the P-38 model is tweaking the mixture, etc to get the best out of it.
I flew my route the other night, with real world weather ( relatively clear ) and it took me 41 minutes t/o to touchdown on rwy 11.
Since this weekend is your flight, you get to lead <G>!!
cya,
I will await until Thurs. to get the "vitals" of from where to where and how......ok the flight plan. I too like the idea of going from place to place, who knows by June I might "sponcer" a flight!
TB:We're hoping whatever prevented you from joining the Thursday chat wasn't too serious. We saw you briefly in ACARS, but not on RW or in the chat itself. Do you know that if you start RW directly and click the "join" button it will often give you the oportunity to connect to the the same server you were last using?
It looks like the Moffett Federal to KSBP route is a go for what in our time zone is the 10:00 PM February 14 flight. You should be able to click the "Printer Freindly" link at the top of the page and use your browser to print out the first page (or two) of this thread to obtain a hard copy of the route. You might need to use the Print command on your browser's File menu to get the option to print only the first part of the thread. Don't hesitate to ask here or at the Saturday chat if you need advice on entering the information into the Flight Simulator flight planner.
Hi Robert,>Both Routes are interesting to me. Let's fly one February
>could start at Catalina!Been reading along with interest recently, trying to get up the nerve to figure out the RW, flight rooms Etc and join in one of these weeks.
I have actually been spending a lot of time in the last month or so looking for a suitable Spitfire to add to the VPC FS2004 Hangar for these flights. Still looking for the right one, for one reason or another, while PL965 vII is still in the engineering hangar.
Is it right that you all are flying the P-38 on these Saturday flights? I gave it a few test flights last month and it is a good aircraft, fun to fly.
The main reason why I chimed in was when you mentioned starting from Catalina. On a plan from Catalina, don't forget to incorporate the SFRA over LAX into the flight. I have piloted the SFRA both in Flight Simulator and the real world, and it adds a touch of class to any Flight Plan, in my opinion.
Melo
PL965 Spitfire pilot,
Glendale, CA![]()
I am not familiar with what SFRA stands forI hadn't realy looked at the Catalina to San Luis route before today, but on the "poster" from the back of Ben's FS 2000 book the 310° radial outbound from Santa Catalina along victor airway V-37 looks like a good first leg. There are a lot of VOR labels in that part of the map, and I'm not completely sure which label goes with the other end of V-37 (Ventura?). I'll check in the FS 2004 flight planner later. From that VOR the route over Fellows then to San Luis looks promising.
Of couse, since we know the controler we shouldn't have any problems getting clearance if we want a better look at Los Angeles
I don't have a Los Angeles terminal area chart.Robert
> I am not familiar with what SFRA stands forSpecial Flight Rules Area
> first leg.I actually had a flight to and from Catalina originally for that book, but at the last minute, Microsoft made me pull it because the Catalina that shipped had a phantom runway there.
> (Ventura?).Ventura is correct.
> VOR the route over Fellows then to San Luis looks promising.Flying a hi-perf multi-engine aircraft over V-37 seems OK. (I wouldn't try it in a single.)
> I don't have a Los Angeles terminal area chart.You don't really need one if you have my book. The flight to Zamparini covers the (now termed the "LAX mini-route") procedures. Just reverse them to fly northbound and change the altitude to 4,500.
Here's a picture of the latest LAX mini-route info:
Oops, 4,500' is the old SFRA altitude. The new mini-route altitide is 2,500'.The latest Letters to Airmen can be found here:
http://www.awp.faa.gov/lta/oprdoc/GetFile.CFM?File_ID=2077
Ben,>Oops, 4,500' is the old SFRA altitude. The new mini-route
>altitide is 2,500'.
>http://www.awp.faa.gov/lta/oprdoc/GetFile.CFM?File_ID=2077Thanks for the update. I flew the route back when the altitudes were 3,500 and 4,500.
Melo
Glendale, CA![]()
Greetings Melo:> Thanks for the update. I flew the route back when the altitudes were
> 3,500 and 4,500.Just FYI, on 9/11, all aircraft were grounded. The SFRA never returned, but became the mini-route a few months later.
Hi Ben,>Just FYI, on 9/11, all aircraft were grounded. The SFRA
>later.That's curious. We flew the route in April of 2003, and
flew at 3,500 ft going southbound, and 4,500 ft on the
return from Catalina. I was the pilot on the northbound
flight so I'm sure of the altitude. If the SFRA was
already changed to the mini-route, our flight instructor
did not tell us about it.And of course it seemed correct to me as it was the
identical procedure that I had used previously in Flight
Simulator.![]()
Melo
Glendale, CA![]()
Hi Melo:> >Just FYI, on 9/11, all aircraft were grounded. The SFRA
> >later.
> did not tell us about it.Hmmm, that is curious. Here's the LTA that existed during that time period (issued June 4, 2002 and valid thru June 30, 2003):
FEDERAL AVIATION ADMINISTRATION
LOS ANGELES AIR TRAFFIC CONTROL TOWER
245 WORLD WAY NORTH
LOS ANGELES, CALIFORNIA 90045ISSUED: June 4, 2002 EFFECTIVE:
June 4, 2002LOS ANGELES TOWER LETTER TO AIRMEN NO. 02-01
SUBJECT: LAX VFR "MINI-ROUTE" TRANSITION PROCEDURES
CANCELLATION: June 30, 2003
A two-directional transition for light VFR aircraft has been developed - the
"Mini Route." Fixed-wing, non-turbojet aircraft will transition via the
Santa Monica 128 radial at 2500 feet in direct communication with Los
Angeles Tower on 126.25. LAX must be in a west traffic configuration and
reporting a ceiling of at least 3000 feet and visibility of at least three
miles; Hawthorne and Santa Monica Airports must be VFR. Pilots should advise
Santa Monica, Hawthorne, or Torrance Tower that they are requesting the Mini
Route. Proceed to Loyola College (LMU) from the North or the TRW building
from the South at 2500 feet, remain clear of Bravo airspace, and contact Los
Angeles Tower on 126.25 for clearance.This procedure is available daily from 0830 to 1230 local, weather
permitting. When staffing permits, the hours of operation will be
increased.
If you have questions regarding this procedure, please contact Frank
Sweeney, Support Manager, Los Angeles Tower, at (310) 342-4912./s/
Sherry Avery
Air Traffic Manager
Los Angeles TowerAWP-530.5:Tellier:x6568:7/10/01:530docs\530.5\LTAs\LAXminiLTA02-01.doc:File:
=============================================I don't know if the original TFR post 9/11 cancelling the SFRA is still available online (probably not), and I don't know if there were any LTA's rescinding the above LTA (I wouldn't think they ever rescinded it since the current LTA posted in my other message is nearly identical to the above).
Maybe a quick phone call to the Support Manager at LAX can clarify what your CFI was doing on that date.
Hi Ben,Problem solved. Here is the key phrase:
>weather
>will be
>increased.That day we were flying in the late afternoon so the Mini-route
was already closed for the day. The previous SFRA rules were
in effect for the non Mini-route times, I guess.I saw in the more recent Mini-route message that you posted,
the hours of operation were increased to 24 hrs a day conditions
permitting. So it was a transition phase between the two procedures.Regards,
Melo
Glendale, CA![]()
Hi Melo:> Problem solved. Here is the key phrase:
> >weather
> >will be
> >increased.
> permitting. So it was a transition phase between the two procedures.I think there's a bit of confusion here (easy to do). I contacted LAX Tower Support Specialist earlier to verify my information. We'll get back into this topic some more when we start discussing the flight, but the quick synopsis is SFRA disappeared after 9/11. It came back as the current LAX Special Air Traffic Rules Area at some unknown point (it's not Steve's airspace and I'm still searching for when). The mini-route was created in June 2002 and both (SATRA and mini-route) exist today. I seem to recall that the mini-route (before they called it as such) was the only way to VFR transition LAX Class B at one time, but can't recall when it was. Finally, there current LAX TAC is erroneously missing the SATRA freq (I posted a note about it in the Safety Forum).
So a plane could fly at 6500 along most of V21 from Catalina (KSXC) to Seal Beach (SLI), then at 2500 along V23 to the 308 (128+180) radial inbound to SMO (includes the mini route)? I see 100/80 (S of San Pedro)and 100/70 (W of Hunington Pier)notations in what appear to be the same airspace boundries most of V21 goes through. With single color printing in the book I'm not sure if any of the other airspace layer information applies in the imediate area of the Seal Beach VOR.Since I would be using the flight planner that comes with the simulator I would probably use Intersection VPCAR as a waypoint and advise pilots to intercept the 308 radial to SMO and use radio navigation for the leg from the vicinity of VPCAR to SMO. The whole exercise would be for sightseeing purposes, since the overwater V27 would be a shorter route towards KSBP.
Would single engine planes normally go for as much altitude as clears the overhead airspace during the over water leg of such a flight, to give them more glide range in the event of engine failure?
> inbound to SMO (includes the mini route)?Yes, you could do that. But let's not get too caught up in flight planning that we forget that we're flying VFR here. As such, you can simply fly a heading or SXC radial outbound to intercept the mini-route.
> information applies in the imediate area of the Seal Beach VOR.Those indicate the LAX Class B airspace. So yes, you need to avoid these bits of airspace except for the portion that the mini-route crosses.
> towards KSBP.Understood.
> give them more glide range in the event of engine failure?Let's look at this in two parts: The first and most important issue is safety. When overflying water, you should plan your cruise altitude to give you as chance to gliding to land in case of an engine failure as you can. So the cruise altitude would vary based on the glide performance of the aircraft. (My good friend and first flight instructor was lost over V-27 in the area we're talking about, so this subject hits close to home for me.)
The second issue is airspace. If you're on an IFR flight plan, crossing Class B is not an issue. Conversely, if you're VFR, then yes, you'd need to cross above 10,000'. However, V-27 + V-25 is outside of LAX Class B, so any VFR cruise altitude would be acceptable, but not necessarily safe.
We should probably break this out into another thread is there is more to discuss.
>I am not familiar with what SFRA stands for![]()
Ben described it well below.
When the group flies, does everyone fly the same aircraft? Or do the guys fly a variety of aircraft?
Melo
Glendale, CA![]()
> guys fly a variety of aircraft?Usually not, and we usually all don't from in from the same departure point, but that seems to be the trend recently. I don't think it's a bad thing because I'm getting the feeling that it's helping everyone learn a little more about aviation flight planning and procedures.
Hi Ben,>Usually not, and we usually all don't from in from the
It actually sounds like fun to fly along in relatively
close formation. One question I had about flying
together. How close can the aircraft get in your flight
room without a Flight Sim collision. In Fs2004, is it
possible to be tucked in behind the flight leader on his
wings without problems. I would hate to get too close and
cause a problem for one of the other pilots.I remember flying in close formation in FS2002 with Kit
Spackman once over Switzerland. I was in a Lockheed Super
Constellation and he was in a Lockheed Starliner. We never
got close enough to have wings overlapping, but we flew
side by side for a while and it was great fun.
I agree that the flight planning info is helpful. I'm
learning useful stuff just from reading this one thread.
Because I usually fly a Spitfire on simulated missions, I
am used to flying wherever I want, (and not holding a
steady course for more than 30 seconds in some situations)
Learning about the correct flight plan procedures and
routes is fun. Lots of good stuff to learn.Regards,
Melo
Glendale, CA![]()
Greetings Melo:> It actually sounds like fun to fly along in relatively
> room without a Flight Sim collision.You have to turn off the collisions with other aircraft option in FS. Due to lag and unpredictable crash boxes of the various aircraft, we had found that we'd get crash errors when we were as far as .2 miles away from the others.
> In Fs2004, is it
> cause a problem for one of the other pilots.Not a problem if you turn off the crash into other aircraft option.
> routes is fun. Lots of good stuff to learn.Well, I hope you're able to join us sometime.
Hi Ben,>You have to turn off the collisions with other aircraft
>others.Thanks, I will be sure to set that option.
Definitely. I was going to shoot for this weekends flight but
the other day I got an invitation to join a friend and some of
his buddies in an online IVAO flight. I will try that flight
this weekend and then join up with you guys the next weekend.Regards,
Melo
Glendale, CA![]()
G,day All,
Firstly Robert.. I thank you for up-loading my route plan for last week, very amiss of me not thanking you during the flight.
Now, this is more like it guys, flight plans coming in from everywhere.If we keep at it it must arouse some interest/support for VPC. I can just picture 20plus P.38,s arriving at KSBP.
Sadly won,t be able to make the flight 15th, might be able to join on RW.
See you all Tuesday chat,
Got it . THX
G,da guys,
Looks like I,m missing all the fun.... WOW look at this post... great to see
AFLD - KSBP. Unfortunately still in Sydney so have to miss the flight.but hopfully might be able to listen in.. see how I go with this old "clunker" laptop.
Really good to see all the discusion re the flights, it,s what we hope for I think, a keen interest in the flights and realistic planning of same.
It is early days and I feel sure we will soon "close up" our formation flying with prior discussion of alt., positioning , speeds, etc. and practice
Hope to at least chat with you all tomorrow.
Have a good flight guys,
Andy.
Speaking of Moffett, I have an actual flight plan from KSQL to San Luis Obispo that I've used a few times in R/L if anyone wants it I can scan it. Moffetts a very cool air field, I'm about 15 minutes from it, not very bussy anymore but you can't miss the two giant runways and the blimp hangars right off the freeway.
-Dylan
