This FlightAdventures install will install the flight situation to be used in VPC Rally #17. The flight features the Wright Flyer at Kittyhawk, North Carolina.
Notes:
- Connect to the flight (We'll be using Flight 1 - Persistent World Flight)
- When it is your turn to fly, load the "Rally 17 start" flight from the Flights: Select a Flight...: My Saved Flights: Choose a flight box.
- Flight Simualator 2004 must be shut down before installing this add-on.
- You must have FS2004 installed for this utility to be of any use!
- This utility has only been tested on Windows XP systems.
- This install contains an uninstall.
Download the file here
