LAST EDITED ON 10-02-03 AT 13:44z ()just thought i'd share this, i was flying from Antartica to Argentina and i came across the Northern light pretty beautiful sight to see
location
first sighting
lat s63* 47.46'
long w57* 20.08'
it was the whole time i kept under the clouds
9592 (i went up to a altitude of 25 000, and could still see it)
the settings
i used real weather a static shot
it stated low clouds, vis 10 mil
heading 313
09:20:26 local time
august 7th 2003 winter (looks like a long winter in Antartica)
Greetings jayboy:I think I can get you started. From FS2K4's menu, select World; Map. Make sure the Aircraft radio button is selected. Type in your coordinates and click the OK button. This will position your airplane in the right spot.
From the same Map, you can zoom out and look for airports and/or NAVAIDs to use in a flight plan.
