Hi guys,another thing:
I often use ATC through RadarContact and have to record the stuff (that
means ATIS and commands) for later use in my reports to the virtual
airline. Also I would like to include the flight schedule, e.g. airports
on the route, times, navaids etc.
Do you know any wordprocessor templates for this task? I thought it
would be nice to have some fields or checkboxes for regular stuff like
clouds at XXX scattered / overcast / thunderstorm, visibility,
temperature, winds etc. - you get the idea.
How does a real pilot do his flightplanning on paper and how does he
record ATIS stuff and such during the flight?
Guido
-OLR.PL v1.82-
Last question first - I used a small kneeboard and a pad and wrote my clearances, etc. on it. Doesn't have to be fancy.When I started I used the FAA flight plan forms but you can make your own, just make some colums for waypoint, heading, ETE, ETA, ATE, ATA. This can be as simple as a piece of paper with columns.
With big aircraft they feed the routes into thie onboard computers.
