Thread Number: 662
"How to display either ADF or VOR 2"
Posted by arts on 11-23-02 at 02:36z
I have looked everywhere and punched all the keys I have not been able to change displays of either ADF or VOR2. Sorry about such a dumb question but after serveral hours it gets d**n frustrating.Art
- RE: How to display either ADF or VOR 2,Ben_Chiu, 01:00z, 11-24-02
- RE: How to display either ADF or VOR 2,arts, 03:40z, 11-24-02
- RE: How to display either ADF or VO...,Ben_Chiu, 19:36z, 11-24-02
- RE: How to display either ADF or VO...,arts, 21:31z, 11-24-02
- RE: How to display either ADF or VO...,Ben_Chiu, 22:54z, 11-24-02
- RE: How to display either ADF or VO...,arts, 00:41z, 11-25-02
- RE: How to display either ADF or VO...,Ben_Chiu, 22:37z, 11-25-02
- RE: How to display either ADF or VO...,PaulCroft, 17:25z, 11-25-02
"RE: How to display either ADF or VOR 2"
Posted by Ben_Chiu on 11-24-02 at 01:00z
Greetings Art:No such thing as a dumb question.
I'm not sure I understand what you mean by change the display. Also which aircraft are you talking about.
Posted by arts on 11-24-02 at 03:40z
Hi BenHaving a VOR and an ADF visible on the instrument panel, I would like to disable the ADF and display the second VOR. I was using the 182 RG and it has one VOR and the ADF displayed.
TIA
Art
"RE: How to display either ADF or VO..."
Posted by Ben_Chiu on 11-24-02 at 19:36z
Greetings Art:> Having a VOR and an ADF visible on the instrument panel, I would like to
OK, now I understand.
Unfortunately there's no built-in, fool-proof way to do what you want You'll need to either use a panel editor or manually edit the panel.cfg file in the 182rg/panel folder (make a backup first!).
Look for the line:
gauge00=Cessna182rg!ADF, 454, 169
and change that to:
gauge00=Cessna182s!VOR2, 454, 169
Posted by arts on 11-24-02 at 21:31z
Thanks so very much!!! No wonder I could not find any way to do this. Where would I get a panel editor? Again thanks so very much!!Art
Posted by Ben_Chiu on 11-24-02 at 22:54z
Greetings again, Art:> Thanks so very much!!! No wonder I could not find any way to do this.
It's too bad it it's much harder to do in real life!
Perhaps I should have been clearer. You can make the edit changes in my last message using a standard text editor like notepad (which comes with Windows). The panel editor usually makes panel changes "easier" by adding a graphical interface. I'm not sure (MS only sent us the standard version to review), but FS2k2Pro may have a panel editor. If not, you can check the usual suspects (avsim.com, simflight.com, flightsim.com, simviation.com, etc.). I don't know if there are any specific FS2K2 panel editors out, but if there is one, it'll show up at one of those sites.
Good luck!
Posted by arts on 11-25-02 at 00:41z
Hi BenNo problem I did use Notepad and I will look for an editor. My only other question at the moment is where do you find the specs to know what to enter in the various panel configs.
Thanks Again
Art
Posted by Ben_Chiu on 11-25-02 at 22:37z
Greetings Art:> No problem I did use Notepad and I will look for an editor. My only
I haven't looked at it yet, but I'd assume the Panel SDK for FS would have all of the gory details. Check the Flight Sim site at Microsoft (there's a link to it from the FS2k2 menu).
Best!
Posted by PaulCroft on 11-25-02 at 17:25z
Hi Art> Where would I get a panel editor?
Check out: http://www.cfgedit.com/
'cfgedit' is a great freeware panel editor I use to tweak panels. I don't know how up to date this link is. If you draw a blank, try searching Google or similar for 'cfgedit.exe'
Registered to: Paul F. Croft
