Thread Number: 661
"VPC Flight Rally #11"
Posted by James on 11-22-02 at 23:36z
The Staff and Crew would like to invite you all to the forthcoming VPC Flight Rally #11. This
flight will take place on Sunday 15th December 2002 arriving at the destination airport for 20:00
BST and then into the Pilot Lounge for the usual chat and the virtual burger and beer afterwards :-)
This months destination is to Aspen-Pitkin Co/Sardy (KASE) Colerado.
Listed below is a cut down version of data available to you for this flight.
Altitude - 7818 ft
Mag Variation - -12.1 deg
ATIS - 120.40 Mhz
CTAF - 118.85 Mhz
Tower - 118.85 Mhz
Approach - 123.80 Mhz
Ground - 121.90 Mhz
Rwy 15
Approach Course 148 deg
Length 7006 ft x 100 ft Wide
Rwy 33
Approach Course 328 deg
I haven't checked but Rwy 15 May have an ILS IPKN 108.50 Mhz @ 27 nm please check. My FSNav shows
this a grid square below Rwy 33?!
Aspen as most of you may know is the long standing December Rally Destination :-) Lots of snow and
ice around so bring your ski's along :-) Also watch your approach as it's apparently not as easy as
it looks :-)
Remember folks, fly safe and have an enjoyable flight.
NB.
Please look up this airport and scenery for your particular version of Flight Simulator, Fly etc.
Anyone wishing to can fly online with me as I fly online from departure to destination, just look me
up in the Flight Terminal.
"RE: VPC Flight Rally #11"
Posted by Emile on 11-25-02 at 06:43z
Hello James,
Strange airport, the data available in FS2002 seams incorrect, if you follow the ILS to land on runway 15 you are in the hill,; the airport is 1 mile left
I will try again
Posted by James on 12-08-02 at 20:20z
Hi Emile,
Sorry for the delay but been on holiday.
As I mentioned in my initial post the ILS -IS- not lined up with the runway! Don't know why!!!
The airport was/is the traditional location for Christmas within FSFORUM and GAMERS <s> so thought I'd carry it on :-)
Posted by Ben_Chiu on 12-10-02 at 06:56z
Welcome home, James:
It's usually due to terrain or other obstacle clearances. Actually, many ILS's are not exactly in-line with the runway. Some are offset when there are parallel runways with ILS's as well. Of course, those with large offsets won't do CATIII approaches. :)
Posted by James on 12-10-02 at 16:35z
Good to be home (for now) :-) Understand the offset's but if you look at the Runway and ILS Approach within FSNav it's wayyyyyyyyyy offfffffffff <BG>
Posted by Ben_Chiu on 12-13-02 at 23:41z
Greetings Emile and Andy:
I downloaded the IAP for KASE last night off the AOPA site and don't see an ILS there.
> I agree with Emile re KASE ILS 108.5.
It looks like the localizer on 108.5 is for PKN, not ASE. I suppose that would explain why you're having problems! :)
> Tried it and it passed me right
> over the FS Nav and the GPS but some 3 miles to the SE of KASE runway.
> Glide slope did not come active so I stayed WAY up there. :)
Ah, this may help: An ILS consists of a LOCALIZER (horizontal guidance), glideslope (vertical guidance), and marker beacons (provides distance waypoints along the localizer). Therefore, a localizer itself will NOT have a glideslope.
HTH!
Posted by Ben_Chiu on 12-16-02 at 21:24z
Greetings guys!
Sorry I had to cut out early yesterday, but I was able to make it to ASE albeit earlier than the scheduled Rally time. I was using real weather, and was wondering if anyone noticed the severe windshear on approach to ASE? I think it may have to do with a quirk in FS's weather system and the high elevation of ASE (the winds aloft forecast and actual METAR from ASE causes the radical change in conditions).
Merry, Merry!
Posted by vgbaron on 12-17-02 at 02:35z
Ben -
I came in about 1/2 hour after you also using real weather and had no problems with wind shear.
Posted by James on 12-17-02 at 12:12z
I was getting wind shear at 13500 prior to Finals fluctuating between 9 and 35kts?! Once below 9000 it settled!
Posted by Ben_Chiu on 12-18-02 at 03:07z
Greetings James:
What I experienced was a strong crosswind on the VOR approach, then an abrupt change in wind direction somewhere around 2000-2500' above the airfield. That's weird that we all experienced different things.
Posted by James on 12-18-02 at 17:35z
I was about 45nm out from the VOR and dropped from 13500 to 11700 when I noticed the radical fluctuation in speeds and directions. All changed again from the VOR till touch down at different altitudes, weird or what <s>
Posted by alanpugh on 12-22-02 at 13:16z
Hi, it's been a while since my last post - have been
working two jobs and also having a problem understanding
what I need to do to get the flight rooms to work.
I flew into Aspen yesterday (a little late, I know) and
used the flip chart booklet, U.S.Terminal Procedures,
Southwest, vol 1 of 2. The approach to rwy 15 starts at
Red Table VOR (DBL) at 14,000', then fly 164 deg.
altitudes are 12,700 at 3 nm from DBL, 12,200 at 6 nm,
10,400 at 9.5 nm then you're only 2-3 mi out.
There is no mention of a published approach for Rwy 33
although if you approach the localizer on 300 deg and turn to 330 over the station, you will be lined up about 13 mi out and have to pass between two hills on short final (you're on your own).
The minimum safe altitude from that direction is
15,500 at 25 mn.
I flew a Lockheed Constellation and came in too high.
There was a conflict with the AI traffic taking off in
the opposite direction so I went for the grass <g> and
made it in ok.
Holiday Greetings
Posted by Ben_Chiu on 12-22-02 at 19:11z
Greetings Alan:
There's really nothing unusual there. There's nothing to break, so if you just play around with it a bit I'm sure you'll get it. Nevertheless, here are some basic instructions.
To join a Flight:
1. Enter the Flight Terminal
2. Click the Flight # button of the flight you wish to join.
3. Once you're logged into the room of your choice, click the Fly Now! button. That'll autolaunch your flight and your flight sim and will join the session in progress.
To Host a Flight:
2. Click the Flight # button of the flight you wish to host.
3. Once you're logged into the room of your choice, click the Fly Now! button. That'll autolaunch your flight and your flight sim and set you as host.
Let us know if you have any problems or questions.
That sounds right.
For those following along at home, here's the plate:
http://edj.net/cgi-bin/echoplate.pl?SouthWest/ASE_vd_gC.GIF
Actually the approach is a circle to land approach and no specific runway is listed in the approach title, so either runway can be used (e.g. there's no specific runway requirement).
> 15,500 at 25 mn.
The localizer is for the missed approach, so if you use that "arrival", as you say, "you're on your own". :)
Easy to do. From the plate it lists 9.67 degrees as the descent angle!
> made it in ok.
Any landing you can walk away from... :)
Merry Merry!
Posted by andor on 12-13-02 at 22:41z
G,day James, hope you had a good holiday, sounds ominous tho', do you have to work over Xmas ?
I agree with Emile re KASE ILS 108.5. Tried it and it passed me right over the FS Nav and the GPS but some 3 miles to the SE of KASE runway. Glide slope did not come active so I stayed WAY up there. :)
See you in Aspen.
Posted by James on 12-14-02 at 15:12z
Hi Andy,
Yep, this ones gonna be a tricky one for some :-) but here's hoping every one makes a safe touch down :-)
I'm on call over xmas and hope to get a call or two as I get a day added to my holiday entitlement (even if I'm only out for an hour or two :-)) plus Double time. Love holidays and having to work <LOL>.
Posted by Emile on 12-15-02 at 06:57z
Hello,
I will not be present. It is our Christmas LIONS Service Club WE . Yesterday evening I was selling "vin chaud" (hot wine) in a challet downtown Brussels and today we organize our Christmas afternoon for the old people having no family and financial support, at least they have a chance to eat, sing and dance this afternoon..
See you at the next Rally and Merry Christmas to all.
Posted by James on 12-15-02 at 12:48z
Hi Emile,
Sorry you can't join us but have a nice day all the same my friend.
Seasons greetings to you and your family.
