The Staff and Crew would like to invite you all to the VPC Flight Rally #8.As you are all no doubt aware that this month is the 1st anniversary of the terrorist atrocity against not only the World Trade Center but against the world in general.
To mark our respect as Flight Simmers this rallies destination will be to KENNEDY INTL - NEW YORK - KJFK on Sunday the 8th September 2002.
Altitude 9 ft
Mag Var 12.9 deg
Listed below are just a few of the many frequencies available. Please look up any others you may require.
ATIS 115.10
Tower 119.10
Approach 123.70
ILS/BC Rwy 13R IMOH 111.35 @ 27 nm Length 14563 ft x 150 ft Wide Approach Course 134 deg
ILS/DME Rwy 22R IJOC 109.50 @ 27 nm Length 11352 ft x 150 ft Wide Approach Course 224 deg
ILS/GC Rwy 31L IMOH 111.35 @ 27 nm Length 14563 ft x 150 ft Wide Approach Course 314 deg
ILS/DME Rwy 4L IHIQ 110.90 @ 27 nm Length 11352 ft x 150 ft Wide Approach Course 44 deg
This area is depicted fairly well in FS98/FS2000/FS2002 and we are all looking forward to as many of you as possible in joining us for this rally. We will also hope to see you in the Pilots Lounge for the usual after flight chat which starts at 20:00 BST.
Have a safe and pleasant flight from where ever your point of departure may be. I would also think it fitting that all aircraft taking part be of 737 and higher (if you wish).
CON,I will make the trip, just can't promise using "Heavy Iron".
"TD - Virtual FAA investigators are on line 2, AGAIN!!!
