Thread Number: 582
"Display Resolutions"
Posted by Mike_Greenwood on 08-23-02 at 03:29z
Moving to another thread .
>>OK - here's the correct key:
"DefaultSettings.XResolution"=dword:00000400 (1024)
"DefaultSettings.YResolution"=dword:00000300 (768)
I'm still lost (not hard to do). Where are those keys in the registry
(path). I guess I should just search for those keys replacing the
numbers to match my current resolution?
- RE: Display Resolutions,vgbaron, 00:57z, 08-24-02
- RE: Display Resolutions,vgbaron, 15:41z, 08-26-02
- RE: Display Resolutions,Ben_Chiu, 19:14z, 08-26-02
"RE: Display Resolutions"
Posted by vgbaron on 08-24-02 at 00:57z
Let's try this ONE MORE TIME!!!here is the key and the subkeys -
HKEY_CURRENT_CONFIG\System\CurrentControlSet\Control\VIDEO\{C49B271F-A97F-4621-9A84-F91C2C1B4EA6}\0000
Look for the MAIN key HKEY_CURRENT_CONFIG......
and change the default settings.
Posted by vgbaron on 08-26-02 at 15:41z
Now THAT'S wierd! Twice now I've pasted the entire key in the message and twice it has NOT show up. Haven't the faintest idea why. Sorry - when I get home I'll try posting it differently and also emailing it to you. Possibly a sequence that is an HTML escape code or something.
Patience is a virg.......Virtue<G>
TTYL,
Posted by Ben_Chiu on 08-26-02 at 19:14z
Hi Vic:> Now THAT'S wierd! Twice now I've pasted the entire key in the message
DCForum's attempt to make it easy for those not familiar with HTML automatically converts many HTML tags. Your best bet is to try previewing your message online and replacing the converted tags with text descriptions such as "*=open square bracket"
