Thread Number: 554
"VPC Flight Rally #7"
Posted by James on 07-29-02 at 19:58z
The Staff and Crew at flightadventures would like to invite you all to participate in the VPC Flight Rally #7 taking place on Sunday the 11th August 2002 to the USS CARL VINCENT (heres hoping I spelt it correctly <s>).I chose this location as some one not so long ago ask'd me for a challenge
So, for that lucky person lets see you land on this
I know this Scenery is in FS98/2000/2002 so no one should have any problems. One thing I suggest you all get is the Arrester Cable programme. You then need to install it and after starting FS start the Arrester Cable programme. YOU WILL NEED IT
NO HELICOPTERS ALLOWED
You can fly from which ever location of departure you wish but the best way to locate the Carrier is to fly to or from PHOG - Kahului Rwy 20 then adjust course to 204 deg. After 10.8 nm (TEBBS) turn Left to 190 deg. ILS/DME is 110.30 Mhz.
The Arrester Cable programme can be found at flightsim.com file name arrcab24.zip. This version is for FS2000/2002 so the guy's running FS98 will have to do a search for their particular version.
We hope to see as many of you as possible on the flight deck. Have a great flight.
- RE: VPC Flight Rally #7,Ben_Chiu, 06:16z, 07-30-02
- RE: VPC Flight Rally #7,James, 19:57z, 07-30-02
- RE: VPC Flight Rally #7,jerryrosie, 13:20z, 07-30-02
- RE: VPC Flight Rally #7,Emile, 14:36z, 07-30-02
- RE: VPC Flight Rally #7,Emile, 05:44z, 07-31-02
- RE: VPC Flight Rally #7,alanpugh, 23:42z, 07-30-02
- RE: VPC Flight Rally #7,James, 10:49z, 07-31-02
"RE: VPC Flight Rally #7"
Posted by Ben_Chiu on 07-30-02 at 06:16z
Greetings!The carrier James is referring to is the USS Carl Vinson (CVN-70).
While we're on the subject, perhaps I can provide some carrier landing tips:
1. Just as with any landing, a good approach is the key. If you make a bad approach, your chances of making a good landing go down significantly.
2. Reducing the amount of fuel you have onboard your airplane will make your aircraft handle and perform better.
3. Real aircraft carriers steam into the wind to reduce the landing distances. You can mimic this effect by adding a wind of about 30 knots (approximately the cruise speed of a modern aircraft carrier) straight down the deck.
4. Make your approach with full flaps and a high power setting. This will allow you to have more control over your landing point.
5. As James pointed out, Flight Simulator doesn't model aircraft tail hooks in the stock version. Although it isn't exactly realistic, you can obtain similar stopping power by landing with your parking brake enabled (Ctrl + .), deploying spoilers (/) and hitting full thrust reversers (hold F2) just before landing.
6. Always be prepared to make a go around (bolter)!
Hope these help, and see you all shipside!
Posted by James on 07-30-02 at 19:57z
Hi Ben,>> The carrier James is referring to is the USS Carl Vinson (CVN-70). <<
I stand corrected my friend
Posted by jerryrosie on 07-30-02 at 13:20z
August 2002 to the USS CARL VINCENT (heres hoping I spelt it correctly<<Absolutely brilliant idea!!
Cheers, Jerry (N94)
-= VPC OffLine Reader Version 1.1.3.0 =-
Hi Jerry,Glad you approve
doing a search in FS2000/2002 for some real cool Dangerous Airports (I have the DA Scenery Scenery Scenery add on for FS98) for other flight rallies in the future
Enjoy and heres hoping you keep your feet dry on touch down
Posted by Emile on 07-30-02 at 14:36z
Damned!! I cannot be present, I will be on holiday in France, and I agree this a brilliant idea.
Guys, take care if you miss the flight deck there are a lot of sharks and baracudas...I will think of you from the back of the garden or on the last hole of the golf course (the 19th)!!
Have fun and please provide some statistics..
At that time in Sully-sur-Loire , Loiret ,France
Hi Emile,Sorry you can't make the rally on the day but hope you try it at some stage and let us know how you did
Have a great holiday
If we ever meet up we'll have to go for a round of Golf
Posted by Emile on 07-31-02 at 05:44z
Greetings James,
It will be my pleasure
Have a nice day
Posted by alanpugh on 07-30-02 at 23:42z
James,Sounds like an excellent choice for a challenge. I'll
try to get my act together and join you with a proper
hookup in the flight room. BTW, the Osprey isn't a
helicopter is it? However in keeping with the spirit of
your stern admonition, I'll probably just fly a 172.
See you at mid-deck near the volly-ball net.
Posted by James on 07-31-02 at 10:49z
Hi Alan,>> BTW, the Osprey isn't a helicopter is it? <<
Depending on which way you look at it but, if you wish to fly it go ahead
See you topside
