Thread Number: 545
"Rogue Dialouts"
Posted by BillC on 07-22-02 at 19:37z
Hi Guys...
My networked 'backup' PC has suddenly decided to try dialling out at intervals.
Since I use a hardware switch to switch my modem between the two machines, I
can prevent the modem dialling out by switching to the other PC.
How the heck can I discover which program is causing it ?
I don't know where to look...
Thanks !
BillC
Formby, UK
Registered to: Bill Cusick
"RE: Rogue Dialouts"
Posted by Madape on 07-22-02 at 22:32z
Hi Bill
Firstly I would make sure you are not leaving programs that require internet access in the background running, such as Instant Messengers.
Make sure that your Dial Up Networking settings dont Auto Connect to the internet, and finally if your using Internet Connection Sharing make sure you have disabled the 'Dial on Demand' option.
HTH
Sam Harvey
sam@crew.flightadventures.com
Posted by vgbaron on 07-23-02 at 15:58z
> Hi Guys...
> intervals.
> machines, I
> Thanks !
Hi Bill -
I would check that Windows update isn't set to run. If you have ZoneAlarm you can use it to see which program is doing the dialing. Also, I don't recall the site, Pete Dowson recommended it, but there's a program called PROCEXP which can tell you which processes are running. When the computer tries to dial, run PROCEXP and check the running processes - you might be able to tell that way.
-= VPC OffLine Reader Version 1.1.3.0 =-
Posted by PeteDowson on 07-23-02 at 18:28z
Hi Vic,
It's www.systeminternals.com. Lots of useful stuff there including file monitors, registry monitors, port monitors. Yum yum! <G>
Posted by vgbaron on 07-23-02 at 22:32z
Hi Pete -
Thanx - I've bookmarked it this time <G>.
Posted by RickLee on 07-24-02 at 20:01z
If it's something that just happened abruptly, lately... you might want to check into the possibility of the Klez or Frethem email worms that are spreading like wildfire in the past week or so. I spent a few hours the night before last cleaning Klez off of my mother's computer... and a few hours last night cleaning Klez off of my father-in-law's computer. What a mess.
These things have their own SMTP routines which go on the Internet and spread the emails without you having to run Outlook or anything. Just a thought.... and a warning to everybody else out there to update your anti-virus software now. These things don't erase your hard drive or anything, but they are really insidious in the way they work. You don't want to get them.
Rick Lee www.rickleephoto.com
Posted by BillC on 07-27-02 at 06:57z
Thanks Guys...
Haven't had a chance this week to check...been a little tied up, away from the PCs.
Thanks for you replies. I'll take a look at your suggestions and let you know how I get on....
BillC
Formby, UK
