Thread Number: 533
"the rolling circle "
Posted by Extra300S on 07-11-02 at 15:02z
I want to know how to do a rolling circle in FS2002 in the extra330 of gene soucy
"RE: the rolling circle "
Posted by Ben_Chiu on 07-11-02 at 19:00z
> gene soucy
Greetings Greg:
I did a quick search of the web and only found references to the rolling circle for R/C aircraft. You know, if you're really interested in aerobatics, you should consider picking up one of the books on the subject in the AerobaticSource.com store. The best advice I can give you is to do the headwork first (e.g. sit down and figure out what you need to be doing when). For me, that was the hardest part of learning the rolling circle.
I could write a whole chapter on how to do a rolling circle, but I really don't have the time or patience to do that. However, what I will pass along is; the idea is to keep your roll rate constant and use your rudder and elevator to keep the nose slightly above the horizon end enough of either control to keep the airplane turning in the direction of the circle. Note that depending on your attitude, rudder may be used to keep the nose high (as when you're past a 45 degree bank), and opposite rudder will do the same on the other side of the roll, and elevator will be used as "rudder" when you're in the 90 degree bank. Just try and break the maneuver down in to segments. I found that 45 degree roll segments and 45 degree circle segments helped me put it together.
Good luck!
Posted by Extra300S on 07-18-02 at 00:29z
Thanks Ben I will try that in a new aerobatic aircraft the Yak 54M that I just downloaded earler today Ben I tried one in it just for fun and I got it perfect almost every time i did it see what 3 years of flight unlimited can do if you practice the same moneuver the 90* rolling turn
