Thread Number: 462
"Resetting Cockpit Views, FS 2002 and 2002 Pro"
Posted by BanzaiSGI on 04-21-02 at 21:15z
I have loaded both sims seperately and in both, when in normal flying mode, I get the rear cockpit view, even after resetting the view to forward, it seems to default back to rear view.
Any ideas?
Thanks
Jim
"RE: Resetting Cockpit Views, FS 2002 an..."
Posted by Ben Chiu on 04-21-02 at 21:31z
Greetings Jim:
> I have loaded both sims separately and in both, when in normal flying
> Any ideas?
Are you using a controller with view set to one of the hats/devices? Try disabling the controller (I believe it's the "K" key) and see if the problem doesn't go away. If it does, your hat/controller may need to be calibrated. If that's not the problem, one solution is to assign the hat/controller neutral position to the direction of view desired.
