Thread Number: 1065
"FSMap"
Posted by hawkwind on 01-24-08 at 21:37z
Hi Guy's,Been a while for me, retirement sucks. Work more now than I did when I was full time <G>
Just a heads up on a new programme for both FS2004 and FSX. You can get a demo of the prog from http://www.Aerosoft.com/
Been having major problems with both the person I live with and BT's Broadband connection so haven't been around much, and been busy elsewhere.
Hope to catch you all either in a chat or on line at some stage. Uninstalled FSX SP2 as I felt it was more trouble than what it was worth in a lot of respects...
James (Hawkwind) Anderson
4nm SE EGHH
+ UNREGISTERED +
- RE: FSMap,Ben_Chiu, 02:18z, 01-28-08
- RE: FSMap,hawkwind, 20:50z, 02-15-08
- RE: FSMap,Ben_Chiu, 22:13z, 02-03-08
- RE: FSMap,Ben_Chiu, 21:27z, 02-15-08
- RE: FSMap,hawkwind, 10:55z, 02-16-08
"RE: FSMap"
Posted by Ben_Chiu on 01-28-08 at 02:18z
>http://www.Aerosoft.com/ So what's your take on this program?
"RE: FSMap"
Posted by hawkwind on 02-15-08 at 20:50z
Hi Ben,Sorry for the delay but have had a few problems over my phone line and BT getting out to fix it. Fixed it they did but some muppet then decided to dig a trench and took out BT's phone lines for the whole estate. Took them a further 2 weeks to relay it all.
Anyway, FSMap once you get the hang of it in either FS2004 or FSX is quite neat <s>. You can import all the US Sectionals available on AVSIM quite easily without calibrating. The biggest problem folk have is in calibrating maps but once you have done a couple it's a piece of cake.
You can add a gauge into any aircraft quite easy (couple of mouse clicks) which has a 2D panel. Any VC you want to add it to then it's editing the panel config file after you find a place to either place it or remove an existing gauge and insert FSMap's.
On the whole I'd give it a thumbs up. In the next version I'm hoping that Thomas implements the chance of overlaying Enroute Charts onto any sectionals you may have installed.
I think Vic is using it and I haven't had much chance again to test it in Multiplayer so can't comment on that side of it yet. It did work in early beta's.
Talk to you later.
4nm SE EGHH
+ UNREGISTERED +
"RE: FSMap"
Posted by Ben_Chiu on 02-03-08 at 22:13z
>-= VPC OffLine Reader 2.1 =-
>+ UNREGISTERED +
>-OLR.PL v1.83- Hi James:
You need to register your OLR.
Check your inbox.
"RE: FSMap"
Hi Ben,If you mean my email one not had anything from you mate.
4nm SE EGHH
+ UNREGISTERED +
"RE: FSMap"
Posted by Ben_Chiu on 02-15-08 at 21:27z
>If you mean my email one not had anything from you mate. I meant the message board inbox. I re-sent you your OLR regi info.
Best!
"RE: FSMap"
Posted by hawkwind on 02-16-08 at 10:55z
>> I meant the message board inbox. I re-sent you your OLR regi info. << Best!
Will go take a look in a second <s>
4nm SE EGHH
+ UNREGISTERED +
