"mastering the rolling 360 or rolling circle as its called"
Extra300S[Guest]
Click to EMail Extra300S Click to send private message to Extra300S Click to view user profile
07-13-02, 02:29z
Patty I am having trouble mastering the rolling turn in the zivko edge540 for flight simulator 2000 and I got it to work in my flight simulator 2002 pro edition what am I doing wrong here are 5 possibilities
1. not enough top rudder
2. not pushing hard enough
3. not rolling slow enough
4. not pulling hard enough on the begining
5. not doing the moneuver right
could you give me some tips on the moneuver? thanks I am about to go try it agian maybe this time I can master it maybe
  RE: mastering the rolling 360 or ro... Patty_Wagstaff[Sysop] 07-31-02 1
   RE: mastering the rolling 360 or ro... Extra300S[Guest] 08-02-02 2
1. "RE: mastering the rolling 360 or rolling circle as its called"
07-31-02, 20:01z
>maybe
Hello Extra
As good as some of these Flight Sims are, they cannot exactly duplicate the "real" thing....However, in an attempt to answer your question, rolling turns are very hard to do well. They take a lot of practice, harmony and rhythym and precise control inputs. All of these things you might be doing wrong listed above are probably correct. Think rudder and lead the maneuver with rudder. It will help you "slide" around the turn.
Hope this is a little bit helpful.
Extra300S[Guest]
2. "RE: mastering the rolling 360 or rolling circle as its called"
08-02-02, 01:52z
Thanks Patty I was doing all of them wrong until i got the logitech wingman extreme joystick and now i can do them good but not perfect I have flight unlimited it has the basic 90* rolling turn on it so far I have scored a 5.1 and getting better the last time I tried it I got a amazing 6.5 on it so i should think rudder then add rudder in the direction of the turn ok what if its a outside rolling turn same thang rudder in teh direction of turn
