"Carb Ice"
DHamblin[Sysop]
"Carb Ice"
05-23-02, 12:43z
Dave Hamblin
(formerly DaveH on old site!)
Here is a topic that I am sure will generate some opinions and comments. The dreaded carb ice. In my realitively short flying experience I have never had any carb ice problems even though most of my time has been gathered in two planes with Continental engines that have a reputation for it.
I admit to being a carb heat junky which may be why. I prefer not to ever have it! Most people feel you don't need it if you are in the green arc on the tach (on our C150H its 2000-2750). If I am in a long descent at 2000 I will use it, and on down wind I pull it on before I get abeam the numbers and the power reduction. Though I practice power off I generally carry 1500 rpm on approach as I feel the extra heat is good (I've heard the 200A Cont doesn't make enough heat at idle to prevent ice).
Anyway, I still read about ice indiced engine failures all the time and was wondering what other people do and what experineces you have had?? I realize fuel injected engines are very much less likely to ice.
  RE: Carb Ice jerryrosie[Sysop] 05-24-02 1
   RE: Carb Ice DHamblin[Sysop] 05-24-02 2
  RE: Carb Ice Ben Chiu[Admin] 05-24-02 3
  RE: Carb Ice avbug[Guest] 05-26-02 4
   RE: Carb Ice DHamblin[Sysop] 05-27-02 5
jerryrosie[Sysop]
Click to EMail jerryrosie Click to send private message to jerryrosie Click to view user profile
1. "RE: Carb Ice"
05-24-02, 13:37z
> ice).
You are probably right about this issue generating a lot of comment and here is the first of the untutored and unknowledgeable comments that will be posted here But - here it is anyway.... Formation of carb ice is the result of the normal cooling that occurs as a gas(or a gas and atomized liquid mixture in this case) is speeded up and compressed as it is when passing through the throat of a carburetor. Whether or not this ice causes problems is determined by whether of not the formation of the ice restricts the flow of fuel through the . It is more likely to restrict the flow if the valve is closed, partially closed as in idling. So, keeping the RPMs up, ie. the valve more open, will help defeat the bad stuff from carb ice. One caution, I have heard, with excessive use of carb heat is that it introduces unfiltered air into the fuel intake system and the more pollutants you ingest into your engine the greater the chance of engine problems.
Awaiting comments from others more knowledgeable......
Cheers, Jerry (N94)
++++ Registered to: Gerald J. Rosie ++++
DHamblin[Sysop]
2. "RE: Carb Ice"
05-24-02, 15:51z
Dave Hamblin
Yes, I generally close it once I am on the runway rolling out for that reason.
I figure airborne the chances of picking up objects is fairly low. If I was landing in Texas in a sand storm I might consider different.
I just read where the Lycoming in the 152 isn't as prone as the Continental in our 150 due to carb location.
As I mentioned i've never (to my knowledge) had an ice issue (hope I don't) but I continually read of incidents related to it. Yet, I only have met one pilot that had a problem (in a 150, engine actually quit) so I am puzzled as to whether its something to "worry" about or just be "knowledgeable" about!
Hence my post, see what others think!
Ben Chiu[Admin]
3. "RE: Carb Ice"
05-24-02, 17:38z
Greetings Dave:
> for it.
The funny thing about carb ice is unless you can get out and look at it, you never really *know* it's carb ice other than by the tell-tale signs/effects (slight decrease in rpm followed by a increase in rpm). Personally, I've never seen carb ice, but I believe I've experienced it on a few occasions.
That's the conventional rule of thumb that's taught. However, you can get carb ice in the green arc as well. It's just less likely in the green arc.
I teach 1,900 with carb heat on for descents and heat on again abeam the numbers in a 172 (haven't flown a 150 or 152 for a number of years, but 150 series seems to be more prone to carb ice than other trainers that I've flown), but you should do what your POH and/or instructor recommends for that aircraft.
> ice).
1,500 rpm is pretty standard for an initial power setting for a VFR approach to landing in trainers too. Idling for long periods of time has many drawbacks, but again, you should do what your POH and/or instructor recommends.
In the high desert here (in Southern California), it's not unheard of to have carb ice when the surface temperature is in the 90's and cruising in the green arc. You'd think that with the high heat and the assumption that the desert always has low humidity (which is not true) we'd never run into that problem, but it happens.
Rgr that! No carburetor to ice up. :)
I've never heard of an FI engine icing up (other than induction icing, but that's something totally different). It's just not possible.
Anyway, my $0.02.
avbug[Guest]
Click to send private message to avbug Click to view user profile
4. "RE: Carb Ice"
05-26-02, 22:41z
Dave,
Carburetor ice can form under most conditions, weather or not visible moisture is present, and weather or not the temperature is near freezing. Carb ice is very common in humid conditions at temperatures approaching one hundred degrees Farenheight.
Yes, fuel injected engines ice, though obviously not at the carburetor...they don't have one. Induction ice is not uncommon in the winter, when flying in freezing rain, or in conditions conducive to surface icing. These aircraft don't have carb heat, but will have an alternate air source which may be manually or automatically activated. (Automatic alternate air is normally "sucked" open by low manifold pressure, and is usually termed a "suck door.").
Without a carb air temperature gage, carb heat must be applied full-on any time carb ice is suspected, or it is suspected that carb ice may form. There are times when the application of carb heat may cause carb ice to form, or assist in the formation. Additionally, as you identified, airflow is not filtered entering the engine during operations with carb heat engaged. All carb heat is, in most applications, is an alternate door that blocks airflow from the filter, and opens directly into the engine compartment.
The operating engine temperature determines how warm the air is that can enter the carburetor with carb heat on. After an extended descent at idle, for example, little heat is available from the engine; certainly far less than might be available when operating at a higher power setting and slower airspeed.
Carb heat is anti-ice protection, not de-ice protection. It's not there to remove ice (though it can), but to prevent it. Carb heat can remove small amounts of ice. However, a big limitation of carb heat is that once ice forms such that the engine is choked or stopped, there's little one can do to remove the ice until it melts on it's own. I've seen many frustrated pilots who executed forced or precautionary landings with partial or complete power failures, who were embarrassed because they couldn't duplicate the cause of the failure. They were unable to restore power until after their landing...and then the engine ran just fine. Why? The ice had melted.
Carb ice forms as a result of a pressure and temperature drop occuring across the carb venturi. This drop is necessary and the main principle on which the carburetor operates. In the center of the carburetor is a narrow construction which causes the airflow to increase in velocity (up to or more than 300 mph at this single point, at full throttle), and causes the pressure to drop (bernoulli's principle).
When the pressure drops, fuel is drawn out of the float chamber in the carburetor, into the airstream. There it's vaporized and mixed with the air, and then it flows into the intake manifold and the combustion chambers in each cylinder. As the pressure drops, so does the temperature. Ambient air temperatures in the high 90's can quickly drop below freezing. As the fuel vaporizes, moisture is introduced. Moisture is also introduced from the ambient atmosphere. The warmer the atmosphere, the more water vapor it can hold.
The best time for carb ice to form is at lower power settings on the ground when little heat is available, the throttle plate is closed, and only a little ice is necessary to cause airflow disruption through the carb. The second best time for it to form is during the initial power application following a prolonged power off descent. I've seen pilots make forced landings following a go-around; the engine quit as power was applied, or shortly thereafter, and the aircraft was forced to land.
The reason for this is ice had formed during the descent. This ice formed the base for a more rapid formation, on a larger scale, as the throttle was opened to go around. This could have been prevented in part by making a power on approach, by exercising the throttle on approach, by using carburetor heat on approach, and by delaying shutting off carb heat until go-around power had been applied.
Part of the preflight runup checklist requirments for all carburetor equipped piston engine airplanes, is a carb heat check. Most pilots simply apply carb heat for a couple of seconds to see that they can note a RPM drop. This is a mistake. Carb heat should be applied for 10-15 seconds at a minimum. The check isnt' just to check that warm air is reaching the engine, but to determine that no ice had formed, and any ice that has formed, is melted.
I prefer to do the carb heat checks on the runway just prior to releasing brakes, so that the very minimum of time for ice to buildup elapses before going to full power. If you do your carb heat checks in the runup area and then have several minutes before takeoff, seriously consider doing another check just prior to, or on the runway. Ice could have formed in the meantime, and that can be costly.
Water can remain in a liquid state to temperatures as low as -40 deg (c/f). Water vapor may be readily available at even low temperatures, though a common wives tale persists that cold air is too dry to form ice. Not true. In fact, use of carb heat at low temperatures in some cases can induce icing. The conditions under which this occurs are rare; it doesn't happen often, but it can happen. The safest rule of thumb for aircraft not equipped with carb air temperature gages is to use carb heat regularly and whenever necessary.
For aircraft equipped with carb air temperature gages, carb heat may end up being used throughout the year at partial settings as required, to maintain the carb air temperature at the proper setting.
I've experienced carb ice in most phases of flight, from takeoff to landing, to cruise, to ground operations while taxiing. I made a forced landing during a descent out of instrument conditions in a Cessna 182 years ago, due to carb ice. (When I applied the carb heat, the control came away in my hand, having failed. I exited the cloud base with enough altitude to set up a landing on a small gravel strip, and walked away). Also on a number of occasions, I've experienced iced spark plugs; this typically is only a problem during starting.
Go with the manufacturers recommendations. I absence of specific direction, I prefer to apply carb heat in the pattern about midfield, and leave it on for tent to fifteen seconds. I'll make the initial power reduction abeam the numbers, and then shut off carb heat. If I have any inclination that carb ice may be required, I will leave it on throughout the approach. In such circumstances, during a touch and go landing, or a go-around, I prefer to leave carb heat on until initial power application has been made. If operating at more than 75% power in a normally aspirated engine, carb heat should be shut off before reaching 75% power. If operating above 3,000' or higher on a standard day, the engine can't make 75% power even at full throttle, so this isn't an issue. If you fly near sea level, use your best judgement.
Use of carb heat at high power settings on higher compression engines can cause engine damage and detonation by overheating the intake air. If using carb heat at higher power settings, the mixture should be enrichened. The mixture is automatically enrichened during carb heat application, because the heated air is less dense, resulting is a richer mixture). If high power settings exist, manual enrichment is necessary to protect the engine, cool the mixture in the cylinder during combustion, and to reduce the liklihood of detonation.
During normal prolonged use of carb heat at less than high power settings, and any time operating at less than 75% power, a good rule of thumb is to lean the engine while carb heat is applied. If you're only applying carb heat for a few moments, leave the mixture alone. However, if you're going to make a cross country flight with carb heat engaged, lean for it; same for a prolonged descent.
An example of this may be a reduced power descent through clouds or visible moisture in a carbureted engine. Manifold pressures and/or RPM as appropriate, should be closely monitored. I always strongly recommend against power off descents (except for certain training emergency simulation scenarios); this is one good reason why one should avoid them.
If you don't have them, you should get hold of the manufacturers recommendations on engine operation for the aircraft you fly. You can get the general information fromthe aircraft flight manual/pilot operating handbook, but this information is watered down and dummed down, and isn't written by the engine manufacturer. You can contact Continental and Lycoming directly for their recommendations, supplied in a booklet form. You should also refer to the maintenance manuals for information on your aircraft systems, propeller, engine, etc. Much of the good information you'll find there, won't be found in the traditionally used pilot sources.
Good luck!!
DHamblin[Sysop]
5. "RE: Carb Ice"
05-27-02, 01:21z
Dave Hamblin
"I've seen pilots make forced landings following a go-around; the engine quit as power was applied, or shortly thereafter, and the aircraft was forced to land.
Yup, thats the scenerio the one pilot (also with a 150) had happen!
My CFI/friend tolerates my "over use" of carb heat. You are right, the POH (for a 1968 C150) doesn't have a whole lot of info, just a few recommendations.
On a touch and go and/or go around I can (at least on the 150) push the carb heat off with my thumb as I push in the throttle, so the heat is coming off as the power is coming up.
Due to my "paranoia" I typically throttle up during long descents and practice engine failures just to make sure I still have an engine.
We have an EGT but not a carb air temperature gage on it.
Thanks for your thoughts and experiences!!
