We're running a new Beta version of the server for Flight 1's Persistent World of the Flight Terminal. This new version simultaneously supports FS2002 and FS2004 in the same session. Although the current Fly Now launcher will only launch FS2002 session, FS2004 users can connect manually to the IP listed in the Flight Info box.Notes:
1. While FS2K4 supports NAT'ed game connections, you will not see any FS2K2 players because FS2K2 does not support NAT connections.
2. Flight Plans and Status display now works properly (providing flight status, positions, and airspeed for the aircraft) for FS2004 flights only.
3. ATC Radar does work with for FS2002 and FS2004 aircraft within the session, however, the NAT problem listed in #1 governs what you can see.
4. There have been some reports of FS2004 players not being able to see FS2002 aircraft. If this happens, make sure you're not behind a NAT, and if all else fails, try reconnecting.
5. FSNAV does work with the session.
Please report and problems or bugs you find.
Thank you.
