Greetings Emile:> I will, BTW during the Rally yesterday I had several looks at the
> "logging" available in the Flight terminal (being at the office I do not
> remember the "official name") , I did observe that some information is
> not available anymore, only the aircraft is still available, previously
> I did have the position, heading, .....
As far as I know, it still works. Did you try clicking the refresh button? I'll try it out again later when I have a minute.
> I also did find that there is an option in FS2002.cfg allowing to
> transfer all aircraft information when running in multiplayer session so
> that you can "see" the other player's aircraft as they are flying and
> not a default aircraft texture , why dont we use this option?
While it sounds like a neat idea on paper, it really isn't very efficient. You're much better off downloading and installing the aircraft outside of a multiplayer session.
At the Zone, we used to have a set of standardized freeware aircraft compiled into a group that we called Zplanes. Perhaps we should consider doing something like that here? Anyone want to volunteer to put a set together?
