"Pop-up Window"
Simtech[Guest]
Click to EMail Simtech Click to send private message to Simtech Click to view user profile
"Pop-up Window"
10-31-02, 11:39z
Does anyone know how to disable that annoying pop-up "Acars" window?
Thank you,
  RE: Pop-up Window Ben_Chiu[Admin] 10-31-02 1
   RE: Pop-up Window DHamblin[Sysop] 11-01-02 2
        RE: Pop-up Window Ben_Chiu[Admin] 11-02-02 3
             RE: Pop-up Window DHamblin[Sysop] 11-02-02 4
                  RE: Pop-up Window Ben_Chiu[Admin] 11-04-02 6
                       RE: Pop-up Window DHamblin[Sysop] 11-06-02 7
                            RE: Pop-up Window Ben_Chiu[Admin] 11-06-02 8
                                 RE: Pop-up Window DHamblin[Sysop] 11-07-02 9
                                      RE: Pop-up Window Ben_Chiu[Admin] 11-07-02 10
             RE: Pop-up Window DHamblin[Sysop] 11-04-02 5
1. "RE: Pop-up Window"
10-31-02, 19:13z
Greetings Robert:
"Annoying" isn't the word that I'd use for it, but you could use the OLR and ACARS will shut down automatically when you're done reading messages.
Just out of curiosity, did you add flightadventures.com to your trusted sites list or allow ACARS to install when prompted to? If not, the system is not launching ACARS because it can't find it, so the window continues to pop up.
HTH
DHamblin[Sysop]
2. "RE: Pop-up Window"
11-01-02, 15:28z
Hi Ben, thanks for the login help last night.
At home ACARS works great, here at work (NT 4.0, MS Internet Explorer 6 sp1) The ACARS window pops up, it says connecting to ACARS, then it closes (isn't connecting).
You mention allowing ACARS to install, is there something that I can uninstall then re-install? Or a way to check if it is installed.
It used to work here at work as well.
I have run the VPC Config utility.
Dave Hamblin
(formerly DaveH on old site!)
3. "RE: Pop-up Window"
11-02-02, 00:05z
Greetings Dave:
Right click on Internet Explorer, select properties, under Temporary Internet files, select settings: View Objects...
Look for ACARSX Control. You can right click on it to select Update or Remove. The latter will delete the control and the system will download a fresh version the next time you connect.
You might try it again if you've updated Internet Explorer. It seems some updates reset our configuration changes.
Please let us know how you make out. If it doesn't work, you might check for some sort of virus scan utility on you system that's blocking ActiveX controls.
DHamblin[Sysop]
4. "RE: Pop-up Window"
11-02-02, 14:20z
Will do, may be our newest Mcafee AV.
Dave Hamblin
6. "RE: Pop-up Window"
11-04-02, 16:04z
Greetings Dave:
> We go through a Proxy server at
> work (MS Proxy server 2.0). Is there a chance the proxy is causing an
> issue???
Several of us connect here through a proxy, so that may not be it.
I don't know if McAffee's VS can block ActiveX scripting, but it's probably a more likely suspect.
You might check with your system admin to see if port 6667 is blocked. If it is, that would explain why ACARS is not able to connect to the VPC.
Please keep us posted.
DHamblin[Sysop]
7. "RE: Pop-up Window"
11-06-02, 15:45z
Its our Proxy. (I work in the IS dept here). I fired up our old proxy server we replaced and it lets me connect, but not the new one.
So, we will have to see whats changed.
Dave Hamblin
8. "RE: Pop-up Window"
11-06-02, 19:25z
Greetings Dave:
Thanks for the update.
Please continue to keep us posted.
DHamblin[Sysop]
9. "RE: Pop-up Window"
11-07-02, 17:42z
Will do, by the way liked your new article in IAC magazine, nice choice in plane graphics for illustrations!!!
Dave Hamblin
10. "RE: Pop-up Window"
11-07-02, 21:19z
Greetings Dave:
> Will do,
Oh, I didn't know it was out yet. Thanks for the kind words. :)
LOL, well, I know the owner. :)
DHamblin[Sysop]
5. "RE: Pop-up Window"
11-04-02, 12:48z
I removed and re-installed, same issue. We go through a Proxy server at work (MS Proxy server 2.0). Is there a chance the proxy is causing an issue???
Dave Hamblin
