"Lock-up Problem"
jonahbird[Crew]
Click to send private message to jonahbird Click to view user profile
"Lock-up Problem"
10-29-02, 06:52z
Hi Ben
I thought you would be interested in the present position.
Until Friday, when this machine was converted to WinXP, I was still getting the lockups. Win XP has cured all that and the forum comes on quicker than ever before.
To convert we wiped the C drive and made a completely new install, so there might have been a bug of some sort.
Frank
  RE: Lock-up Problem Ben_Chiu[Admin] 10-29-02 1
1. "RE: Lock-up Problem"
10-29-02, 07:34z
Greetings Frank:
Thanks for the information.
Most of the time when there is a problem, it is a problem on the users system. We've testing VPC on many systems and it's always worked on "clean" systems. Unfortunately, there are way too many things that can go wrong with a browser or OS that the only way to absolutely cure some of these issues sometimes is to do what you've done--a reformat and reinstall of Windows.
Personally, I have to reinstall Windows at least once a year. I used to have to do it more often when I was working with a lot of Beta products, but it's really just a fact of life when using Windows--you have to clean it out sometimes.
Thanks again for the update.
