Hi folks,Upgraded my OLR to v2.1 and I'm getting some strange results/observations when I start the prog and hit Get/Send Pass!!
As instructed I downloaded both files. Ran OLR18-setup.exe first and told it to install to C:\VPC (the location of my original programme). It then installs but also creates a folder inside VPC called distribution. Now I didn't have this folder there in the first place so I copied every thing within this folder to the VPC main folder.
I then ran the OLR and noticed it was still reading (in help) version 1.2!!! No problem I thought as I now closed the OLR and Installed VPCOLR21upgrade. No problem with this I thought as I told it to do the same, install to C:\VPC.
I then ran the VPC OLR. Clicked on Get/Send Pass - WOW I thought this is fast, but, nothing happened so I ran it again and yep it started same old speed
fast(ish)
There was no now posts so I created on and sent it. No problem. I then wanted to send another so I created the post and clicked on Get/Send Pass and yep you guest it WOW this is fast BUT the post I wanted to send is still here!!!
Hence this post (if it sends it). Any ideas on what gives??
