Greetings:We've discovered an "issue" with Internet Explorer which causes our VPC Config utility to stop the Lobby menu, UTC Clock, and well, most every other feature from working. This bug should only affect those that have never manually changed their Java permissions. Regardless, we've come up with a fix and have incorporated it into VPC_cfg.exe utility, which is ready for download now.
If you've already run VPC_cfg.exe, we recommend that you run this new version to clear up any potential problems.
If you've never run VPC_cfg.exe, we recommend that you do so ASAP.
http://www.flightadventures.com/misc/VPC_cfg.exe
Thank you.
-OLR.PL v1.78-
