Greetings:Just a heads up to let everyone know that we've converted the Chat Rooms over to the new ActiveX components. Once you're there, you'll also be logged on to our new ACARS system.
Note that the first time you access this new system, there'll be a longer (and it'll be substantially longer for those on dial up) than normal load time. This one-time delay is due to the downloading of the new controls to your system.
To make sure that all works properly, we recommend that IE users use our VPC_cfg.exe program found at:
http://www.flightadventures.com/misc/VPC_cfg.exe
Select Run this program from its current location, and select "Yes" when the warning
box appears.
