I've just downloaded the OLR, and I doesn't want to work.I followed the installation instructions to the letter - steps 1 & 4 worked exactly as expected, but in step 5 there was no "Autostart MySQL" box to check as advised. Clicking the get/send button produced a DOS box with the following at the bottom:
No configuration file found.
Please enter the following values:
Database userid:
Database password:
Database name:
Proxy/none:
You have entered the following values:
dbuser =
dbpasswd =
dbdatabase =
proxy =
These values will be written to your configuration file olr.ini.
OK, to use this values (y/n)?
Hitting Return to leave the database questions unanswered (I didn't know what they should be), and "n" so that I didn't overwrite anything important, the OLR then refused to dial out, and displayed an error message:
CONFIGURATION ERROR
Invalid entry - Unable to LOGIN - Check OLR.INI file!
After shutting the whole thing down, a search of the entire drive revealed no INI file of that name, only vpcolr.ini - should this file be renamed or copied?
Alan - using the browser interface
