"Extra 300L landings made easy"
VPC Forums Flight Training
flycasual[Guest]
Click to EMail flycasual Click to send private message to flycasual Click to view user profile
02-26-07, 06:37z
I just started flying the Extra and it is also my first taildragger. Sometimes on the three point landings I get the shopping cart bebop effect on landing. That's were it bobbles between tail & mains after touchdown. One way I have found to correct this is to push over to a wheel landing to stop the bobble then smoothly to full back stick. It doesn't seem right to have a hybrid three point/ wheel landing. What is the best way to land this beast and where can I go to learn more?
Thanks for your help!
Lefty
  RE: Extra 300L landings made easy ChrisBebensee 07-17-09 1
ChrisBebensee
Click to EMail ChrisBebensee Click to send private message to ChrisBebensee Click to view user profile
1. "RE: Extra 300L landings made easy"
07-17-09, 18:09z
Are you touching down on the runway straight and not drifting? On a paved runway, if you're not fairly aligned and drift free, the plane will do two things, swerve and if it's enough of a drift, it will hop. This is the first skill to master, and since you can't see straight ahead on landing, you have to be good at using your peripheral(diagnal left and right front sides of the nose) references to judge drift and yaw on touchdown. If you're using only one side to judge your alignment, chances are you're yawed away from the centerline somewhat as you touch down. Use both peripheral references and compare them to remain aligned and centered. If you have the impression that you should be "wings level" and crabbing on touchdown instead of slipping for crosswind, your landings just aren't going to work out that well.
Secondly, learn the 3 point attitude and altitude. Sit in the plane and learn exactly where the horizon should be relative to your peripheral references. Altitude is judged based on the apparent geometry of the runway edge lines. THE RUNWAY EDGE LINES :) If you know you're above the runway and not at 3 point attitude but sinking, then you can do something about it - slight flare. If you know you're at 3 point attitude and sinking, you can maintain the 3 point attitude and add power or just flare a little bit more. If you're pitched above 3 point attitude and ballooning, you can deal with it. The goal touch down softly at the 3 point attitude, so you have to be controlling the descent rate precisely as the plane slows down. That means a soft landing with power off will always require increasing angle of attack at the instant of touchdown. The rate of increase of angle of attack depends on the rate of deceleration and rate of descent. You have to be very precise with the pitch increase at touchdown because it's easy to balloon if you pitch too quickly too soon.
From what you described though, I think the problem is alignment with the runway or drift. You're probably only looking out one side of the nose and touching down in a crab or a drift (one and the same thing as far as the forces that will act on the airplane are concerned). Make sure you use both left and right peripheral references to judge your straightness and drift. Do some low passes on a long runway to get the feel for it.
Just so you know, it doesn't matter if you're in a Stinson 108, A Cessna 170, a Pitts S2B or an Extra 300, landing sideways will cause the same basic thing to happen, just at different rates and different frequencies.
Good luck!
