Greetings Chip:> It's a weight threaded to the end of a hose with holes drrilled in all
> directions to pick-up fuel. Check Aircraft Spruce online catalog. It
> should be there.
I couldn't find one online, but I get the concept. It's very similar to the type of tank "clunk" they use in R/C airplanes.
> Not sure how to post a picture, but I can email you one if you wish.
Just FYI, when you post or reply to a message, there'll be a link called Upload file or something like that on the left side of the screen. Follow the prompts and you'll upload the file. As a moderator of this Forum, you'll be able to view the file URL from the Admin panel. If you're interested, I can email you the details of what to do.
> As for the oil sump on the Extra it is a dry sump and uses a 3-way oil
> valve to pull oil from the sump or the top of the engine (inverted
> flight) to the oil pump.
I found a retrofit system in Aircraft Spruce cat:
http://www.aircraftspruce.com/catalog/eppages/christen801.php
It's probably not the same, but I get the idea. It's interesting how such a high tech machine such as an Extra uses such relatively low tech mechanisms. Then again "KISS" (Keep It Simple Stupid) is usually the best way.
Thanks for the insights, Chip!
