"Jul 24 0200z Multiplayer Plan"
RobertVA[Lead]
07-23-05, 23:14z
Los Alamitos AAF to Edwards AFB
Boeing 737-400 or your favorite jet transport
Waypt.
Code
Waypt.
Name
Navaid
Code
Navaid
Name
Navaid
Radial
Navaid
To / From
Navaid
Type
Navaid
Freq.
Alt. Hdg. Dist. Est. Gnd.
Speed
ETE
(hh:mm)
KSLI Los Alamitos             35
KVCV S. CA.
Logistics
VCV Victorville 020 To VOR/
DME
109.40  30,000 020  59 300 00:12
Wpt03   VCV Victorville 324 From VOR/
DME
109.40 17,000 324  31 170 00:11
KEDW Edwards IEDW   224 To ILS 110.10 2.302 224 27 160 00:10
Totals: 117   00:33
Departure Airport: Los Alamitos AAF Code: KSLI Altitude: 35 ft.
Latitude Longitude ATIS UNICOMM MULTICOMM Tower CTAF
33°47.40N 118° 3.05 W 000.000     123.850
Rwy. Length   Navaid
Hdg. / ID
Navaids Frequency Navaid
Hdg. / ID
Navaids Frequency
4L/22R 5,911 ft.
4R/22L 8,001 ft.
17/35 2,800 ft.
Destination Airport: Edwards AFB Code: KEDW Altitude: 2,302 ft.
34°54.33N 117° 53.02 W       120.700
Rwy. Length   Navaid
Hdg. / ID
Hdg. / ID
Navaids Frequency
4/22 15,000 ft.       224(IEDW) ILS/DME 110.10
6/24 8,000 ft.
  • Gliding Practice! Set throttles at IDLE crossing Southern California Logistics / Victorville and LEAVE THEM THERE until touchdown. Use reverse thrust as a substitute for drouge chutes. You may save the floght at this point for repeat attempts.
  • Make 260° right turn after crossing WPT03 to intercept localizer. You may adjust turn radius and or entry point as needed to reach Edwards runway 22. You will need to be well above the ILS's glide slope. If you want to display the route on your GPS, WPT03 is along a line betwen VCV and BORON int.
  • You will probably need to wait until the very last moment to lower landing gear and flaps.
  • I managed to make the landing by keeping airspeed to vicinity of 160 kts most of the way down. Caution Stalls at approximately 143!
  • You may need ded reconing or GPS departing Los Alamitos. It took a while before I picked up VCV (possibly terrain obstructing signal)
  • Altitude at WPT03 and distance after that point are approximate.
  • Don't forget to reduce fuel load before takeoff. I started with 40%.
