"RPM"
Amancio[Guest]
Click to EMail Amancio Click to send private message to Amancio Click to view user profile
"RPM"
04-20-05, 22:39z
My name is Edimilson. I live in São Paulo/Brazil. I would be very help if someone could help me with a problem.
I am a novice at Flight Simulator 2004. It happens that when I increase RPM while running the game (pressing F3) the RPM slows down after I stop pressing this key (F3). I tryed Microsoft support but they told me it is a problem from the way I run, and this kind of problem they can´t help me (It is not a technical problem). It occurs the same with Combat Flight Simulator 3 (with another keys). I would be very glad If I had an answer. Thank you.
e mail: amanciosp@hotmail.com
amanciosp@uol.com.br
  RE: RPM Ben_Chiu[Admin] 04-21-05 1
1. "RE: RPM"
04-21-05, 07:34z
Greetings Edimilson:
Do you have any joysticks or other controllers connected to your computer other than a keyboard and mouse? It sounds like something is centering the Y axis of controller/joystick #2.
If you don't have any controllers connected to your system, you might check out the key assignments and controller assignments, and the sensitivities settings. One of them may be causing the throttle to return to neutral.
Please let us know if any of these help.
Good luck!
