"Apr 3 0300z Multiplayer Plan"
RobertVA[Lead]
04-02-05, 23:22z
Santa Barbara Muni. to San Luis Co. Rgnl.
Douglas DC-3 or other aircraft with approximately 125 knot cruise
Waypt. Name Type Frequency Altitude Heading
(Bearing)
Distance Est Gnd
Speed
ETE
(hh:mm)
KSBA Santa Barbara
Muni
Apt 10
GVO Gaviota VOR/DME 113.80 4,500 282 14 100 00:08
ORCUT Int 4,500 308 24 125 00:12
FLW Fellowes VOR/DME 117.50 046 Radio fix @ ORCUT
only
FABEG
Int 4,500 308 12 125 00:06
FLW Fellowes VOR/DME 117.50 067 Radio fix @ FABEG only
NINOO Int 4,500 308 6 125 00:03
FLW Fellowes VOR/DME 117.50 075 Radio fix @ NINOO
only
CAVLI Int 2,500 018 8 125 00:04
MQO Morro Bay VOR/DME 112.40 277 Radio fix @ CAVLI only
FLW Fellowes VOR/DME 117.50 084 Radio fix @ CAVLI only
KSBP San Luis
Co. Rgnl.
Apt 209 290 6 110 00:03
Totals: 68 00:36
Departure airport information:
KSBA Santa Barbara Muni St/Co: CA UNICOMM: 122.950 CTAF: 119.700
Lat: 34° 25.57' N Lon: 119° 50.42' W Elevation: 10 ATIS: 132.650
7/25 6,049 ft 7(ISBA) ILS/DME 110.30
15L/33R 4,175 ft
15R/33L 4,191 ft
Destination airport information:
KSBP San Luis Co. Rgnl. St/Co: CA UNICOMM: 122.950 CTAF: 124.000
Lat: 35° 14.21' N Lon: 120° 38.51' W Elevation: 209 ATIS: 120.600
7/25 3,175 ft
11/29 5,325 ft 11(ISBP) ILS 109.70
  • Estimated DC-3 fuel consumption: 300 lb.. Remember to adjust fuel level so you won't be too heavy landing at KSBP.
  • Follow 308° outbound radial from Gaviota (GVO @ 113.80) until intersection NINOO reached.
  • As Aircraft is not equipped with DME, use second indicator on radio compass to determine when an intersection is reached. Bearings are provided in the plan for that purpose. You should be able to leave NAV 2 receiver tuned to Fellowes (FLW @ 117.50) for the entire flight. You should only need to retune the NAV 1 receiver to obtain bearing to Morro Bay (MQO @ 112.40) after crossing NINOO intersection. Depending on ceiling and visibility, destination may be in sight by the time you reach NINOO.
Don't forget to check the time for the April 10 flight!
