RobertVA
"Sept 26 0200z Multiplayer Plan"
09-25-04, 13:29z
Moshi Tanzania to Loitokitok Kenya
Cessna 172 SP
Waypoint
| Name
| Type
| Frequency
| Heading
| Altitude
| Distance
| Est Gnd Speed
| ETE (hh:mm)
HTMS
| Moshi
| Apt
| 2,100
| Wpt 01
| wpt
| 112.10*
| 052
| 9,000
| 25
| 94
| 00:16
| HKLT
| Loitokitok
| Apt
| 112.10*
| 331
| 5,445
| 14
| 93
| 00:09
| Totals:
| 39
| 00:25
Departure airport information:
HTMS
| Moshi
| LAT:3° 22.0' S
| LON:37° 19.00' E
| Elevation: 2,100
| 8/26
| 4,159 ft
| 18/36
| 4,856 ft
Destination airport information:
HKLT
| Loitokitok |
| LAT:2° 54.15 S
| LON:37° 31.05' E
| Elevation: 5,445
| 14/32
| 3,281 ft
- Will need to load approximately 35 % fuel and only 340 lb.crew/payload to achieve climb performance required to clear terrain along a straight course to the first waypoint. If that climb performance is not available will need to swing east of radial or circle to climb. Terrain is approximately 8,600 ft approximately 49 nm DME along 52° radial TO MTA.
- *Departure airport to waypoint along 52° radial TO Mtito Andei (MTA) VOR/DME on 112.10 Mhz. Signal will not be available for much of the climb.
- *User defined waypoint is at 3° 6.21' S X37° 37.85' E
- *Waypoint and destination airport are both 41.1 DME from Mtito Andei VOR/DME
- Destination airport along 71° radial TO Mtito Andei VOR/DME
- Route is NOT over MTA, navigational radio fix only.
- Extra time in plan in case anybody wants to change planes and check scenery out some more!
Robert Near KORF
