"Scenery Library"
andor[Lead]
"Scenery Library"
02-28-04, 23:22z
G,day guys,
Re the Scenery Library in FS9.
I have installed Matt Fox,s LC_CAV2 into the scenery library and given it (as per his Read Me File) a lower priority than LAX or SFO, doing so made a marked improvement to the CA landclass scenery, originally I had installed it as "last in" ie No1.
Could someone tell me the reason for this priority of installation as I may unknowingly have problems with other addon sceneries.
Grateful for any advice & TIA
  RE: Scenery Library Ben_Chiu[Admin] 02-29-04 1
  RE: Scenery Library Emile[Crew] 02-29-04 2
   RE: Scenery Library andor[Lead] 03-01-04 3
1. "RE: Scenery Library"
02-29-04, 02:43z
Greetings Andy:
Did you install the VPC version of Central California Coast (KSBP) scenery? If so, then you don't need to install Matt Fox's LC_CAV2 because it is already installed with the VPC version. I don't know what will happen if you have two versions installed.
Emile[Crew]
2. "RE: Scenery Library"
02-29-04, 08:19z
Hello Andy,
I did download and install this LANDCLASS files.
What I have done and it works :
I have all VPC/California sceneries (airports) and textures in 1 folders with highest priority
I have a California Landclass folders (only scenery) just below = less priority
I have the LC_CAV2 landclass folder (I did rename it " California Landclass lowest priority" , only scenery) almost at the bottom of the priorities.
To my understanding a LANDCLASS bgl file may NOT be mixed with sceneries ; it may not be in a folder scenery associated with a texture folder . If you do so the game will "eat" all your memory up to an FS9 error message.
See AVSIM :
Microsoft Flight Simulators MS Flight Simulator General Discussion Forum topic #175241; Your computer has run out of memory, FS will now exit..."
Hope it helps
andor[Lead]
3. "RE: Scenery Library"
03-01-04, 22:06z
G,day Emile,
Many thanks for your information, it would explain the problem I had with the LC_CAV file, I had it in FS9 scenery folder. Will keep checking it out, again thank you.
Andy.
20' S of ytre.
