Greetings ph816:> Hi, Thanks for the response. The actual lesson starts you out just
> south of the facts intersection and tells you to proceed to the 34 L/R
> approach to KSEA. Then you will be instructed to perform a missed
> approach as published. Then after reaching the PARKK NDB, you will be
> cleared to the SEA VOR to hold. When you click on the info for the
> flight, it states you will make the 16R approach.
I see there's a SEA ILS 16R approach. Perhaps someone was mixed up when they wrote the flight info.
> The examiner, once the
> check ride is started says to use the 34R approach. If I try the
> published approach on a 338 heading and descend at the proper rate
> approaching the MILLT (6.0 miles @ 3000') then at DONDO 1600' to the
> MDA, the checkride stops as a failure.
I don't have the FS2K2 charts here, but according to the NOAA plates that I have now show MILLT as being 11nm from the MAP. Perhaps this is what the problems is?
> If I just maintain a heading of
> 338 @ 4000' the checkride continues and instructs me to climb to 2000'
> to PARKK and turn left to 160, climb and maintain 3000' direct to the
> KSEA VOR and hold on the 140 degree. I have done this and have gotten
> this far, but was then left in a never ending holding pattern. I am
> beginning to believe I have a faulty program.
There may be a trigger that switches a flag that you've descended far enough (remember there's an upper limit to the blocks for airspace). If the flag isn't set/triggered, the program just loops.
> The reason I say this is
> because I tried it again, did to loops around the pattern and was then
> directed to the NOLLA LOM, then the ILS approach to 13R @ KBFI via the
> procedure turn. I went through everything with a perfect landing and no
> certificate was awarded. I have completed all the other checkrides
> (Private, Commercial & ATP) and have passed them with no problem.
Hmm, try it again but using 11nm for MILLT and see what happens.
> Thanks
> again for the great site! I see myself spending a lot of fun time here.
Thanks for the kind words. We look forward to seeing you around more often.
