>ok guys, i have xp pro and sidewinder 3d pro joystick. it
>didnt recognize it in fs 2004 but what i did is to go to
>the joystick inteh control panel and "add it" then choose
>form the dropdown menu to pick the correct joystick. it
>worked fine and was automatically configured. i dont knwo
>if this is just for fs2004 or if it will work in fs2002
>also. My configuration is FS2002 and XP Home edition, with a MS Sidewinder 3D Pro stick (gameport).
I found that the Joystick is not operational in FS2002, options are greyed out. When I go to control panel and then Game controllers the joystick is there but listed as Not Connected. Once I either enter and exit from the troubleshooter, or remove and add the joystick then it reports "Ok" and works fine in FS2002 from then on. I have to go through this procedure every time the PC is restarted.
So it works, but is annoying.
Melo
PL965 Spitfire pilot,
Glendale, CA
