Greetings gooper:> Hi ben i will mostly be using it for jet flying as these are my
> favorite aircraft.
As you may know, jets are controlled by yokes and sticks, so that doesn't narrow it down much. For military jets, I think the Thrustmaster F22 (now called the Cougar or something like that) is tops.
> how do u like force feedback as a feature? is it worth it?
The best FFB stick I've used is the now discontinued one from CH products. The current "leader" is the Logitech cable driven model (although I don't really like the grip and prefer the larger CH grip).
Worth it? Like most of this stuff, you can have the best hardware in the world, but if the software isn't up to par, it'll make the hardware seem poor. For example, the CH products stick was very good, but how good it felt depended on the sim you used/FFB programming. For me, the only value for FFB in GA sims is to feel control resistance for learning to use the trim. The ground bumps, gear extend, etc, are just fluff and if anything, distract from the experience IMHO. However, for air combat sims (prop sims in particular), FFB greatly enhanced your ability to detect the edges of the performance envelope--making you a better pilot.
