> Hi Guys...
> My networked 'backup' PC has suddenly decided to try dialling out at
> intervals.
> Since I use a hardware switch to switch my modem between the two
> machines, I
> can prevent the modem dialling out by switching to the other PC.
> How the heck can I discover which program is causing it ?
> I don't know where to look...
> Thanks !
Hi Bill -
I would check that Windows update isn't set to run. If you have ZoneAlarm you can use it to see which program is doing the dialing. Also, I don't recall the site, Pete Dowson recommended it, but there's a program called PROCEXP which can tell you which processes are running. When the computer tries to dial, run PROCEXP and check the running processes - you might be able to tell that way.
-= VPC OffLine Reader Version 1.1.3.0 =-
