Hi Frank,> If you combine this with the Ti4600 you'll think you've died and gone to
> heaven. I only have the 2.2GHz P4 with that card but it goes liked
> greased lightening.
Yes, it is a Ti4600. I'm sorting my Network arrangements now, then I'll be setting up FS2002 on it and trying a flight -- probably get to that by Sunday! <G>
> I am, at last
, trying out projection and as the version I feel like
> affording is XGA and, for the first time with a GeForce, I tried the
> antialiasing setting. It really improved the scenery and aircraft
> outlines but the panel was "swimming" about. I was on the point of
> emailng you for advice but thought I should first try a driver update.
> It did the trick. The driver I now use is 29.42.
Okay -- this came with 29.42 installed already. <G>
But I'm not sure I'll use anti-aliassing. On a quick test with a virgin FS2002 installation the frame rate at Meigs (default Cessna start up) with EVERYTHING maxed out, is around 20 fps, but over 30 fps without anti-aliassing. This is at 1280x1024x32 resolution. Moreover, at that resolution I really would be very hard-pressed to see any difference in image quality. I think anti-aliassing is more suited to lower resolutions, and especially for folks who like looking at the outsides of aircraft.
Best,
