Greetings Avbug!> Some aircoups had rudder pedals, others didn't. The aircraft that
> didn't, which was part of Fred Weiks origional design, were steered like
> cars, using the yoke. Others used rudder pedals and standard steering.
Ah, didn't know that.
> I've even flown large four
> engine airplanes that had only brakes for steering, and a free castering
> nosewheel.
I bet differential power comes in handy when taxiing one of those.
> Johnson bar brakes such as found on the aerocommander single engine
> airplane, have been common braking arrangements.
Sorry, "Johnson bar"? Can you describe what that is?
> Some aircraft use brakes only on one side; the left seat pilot station
> has brakes on many light twins, but not the right seat.
Rgr. I fly with a the owner of a Cherokee like that. Since he's an excellent pilot it's not a big deal, however, I'd imagine I'd be a little uncomfortable giving primary instruction to a new student from the right seat!
> Some aircraft, such as the Twin Commander, use the first part of travel
> of the upper rudder pedal to control steering, and then progress to
> brakes as the rudder is pressed farther down with the toes.
Now that sounds like it's be challenging!
> In short, a wide variety of brake control exists, as well as steering.
Rgr that! Thanks for sharing, Avbug!
